Tips for Kenne Bell BAP ????
Old Dec 15, 2006 | 09:44 PM
*C7*'s Avatar
*C7*
St. Jude Donor 05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17
Default Tips for Kenne Bell BAP ????
The instal is very straight forward.. Any tips for mounting the unit near the fuel pump or running the wires from the pump to the controller under the dash?????
I could get it done but it never hurts to ask someone that has already been there..........
Old Dec 15, 2006 | 10:10 PM
dads01dream's Avatar
dads01dream
Old Dec 16, 2006 | 12:24 AM
Cajundude's Avatar
Cajundude
Active Streak: 90 Days
Cruise-In 7-8-9-10 Veteran
St. Jude Donor '06-'07-'08-'09-'10-'11-'12
I mounted mine behind the rear driver's fenderwell. I didn't do it this way but you could run the wiring through the rocker panels.
Old Dec 16, 2006 | 05:21 PM
kawasaki eric's Avatar
kawasaki eric
I ran the wiring through the rocker panels. Worked great !!!!!!!
Old Dec 16, 2006 | 06:01 PM
DanTTVette's Avatar
DanTTVette
Same for me.
Old Dec 16, 2006 | 08:50 PM
SteveDoten's Avatar
SteveDoten
Cruise-In VII Veteran
Lingenfelter has the basic wiring instructions on their site
they fit nicely on the inboard side of the pass fender well next to the battery, you can't see it unless it's pointed out
Old Dec 16, 2006 | 09:12 PM
BLOWNZO6's Avatar
BLOWNZO6
Premium Supporting Vendor
I mount mine like so.
RR DR Inner Fender near the Fuel Pump
Just run the wires up through the rocker for the Hobbs Switch.
As for the dial wires. I cut them off at the box, solder the ends together and tuck them back inside the box. There is really no need for the adjustment.
__________________
EAST COAST SUPERCHARGING SALES AND TECH SUPPORT
WWW.EASTCOASTSUPERCHARGING.COM
Old Dec 16, 2006 | 10:12 PM
*C7*'s Avatar
*C7*
Default Thanks for your tips
Thanks for all your tips...........
BLOWNZ06 thanks for your tip on the dial wires. I understand your thinking on this and will go with your method. Thanks....
Old Dec 16, 2006 | 10:14 PM
BLOWNZO6's Avatar
BLOWNZO6
Glad I could help.
To Tips for Kenne Bell BAP ????
