using fuel and boost gauges
Old Jan 20, 2007 | 02:23 PM
vetmike01's Avatar
vetmike01
Default using fuel and boost gauges
How many are using boost and fuel gauges with there prochargers?My car is at ecs now and i am try to decide whether or not to get these gauges.Mike
Old Jan 20, 2007 | 02:27 PM
c5mtl's Avatar
c5mtl
i plan to use boost and afr
Old Jan 20, 2007 | 04:08 PM
redcycle13's Avatar
redcycle13
I use autometer Z series, fuel pressure, boost, air/fuel run off a wideband.
Old Jan 20, 2007 | 04:40 PM
keith954's Avatar
keith954
St. Jude Donor '06, '13
i would get then put in now since your car is there getting the novi
Old Jan 20, 2007 | 04:46 PM
MPRTKLR's Avatar
MPRTKLR
I would also highly recommend putting them in. Honestly, you hope that you never really need them, as you car should always have the same boost and same fuel pressure under WOT. However, you want them there so you can detect right away if something is not right. It will also help you diagnose the problem if one should arise. They are definately worth the couple hundred dollars for a decent boost/vac. gauge and F.P. gauge.
Old Jan 20, 2007 | 05:08 PM
peter pan's Avatar
peter pan
Life Time NCM #2196
I have both the autometer boost and fp guage installed since my blower setup went in and now adding the AFR guage
Old Jan 20, 2007 | 05:14 PM
FactoryRaceCar's Avatar
FactoryRaceCar
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12
I have Defi Blue Racer Series. Fuel Pressure and Boost/Vac. I love them
Old Jan 20, 2007 | 05:44 PM
vetmike01's Avatar
vetmike01
Default Gauges
Thank you for all the replys.I think i am going to go ahead and get the gauges installed.I will call Chris on Monday.
Old Jan 20, 2007 | 06:45 PM
FRCBobby's Avatar
0FRCBobby
Former Vendor
I added the Z series Boost and Fuel Pressure when I put my Procharger on. Go ahead and get them
I also plan on a Dynojet wideband in the near future.
Old Jan 20, 2007 | 07:27 PM
trussme's Avatar
trussme
Default A Must!
If you have a supercharger, a fuel pressure guage is a critical safety device. If your fuel pressure drops drastically on WOT, you know to "get off of it" ASAP. The boost guage is less critical, because it is a monitoring device that will let you know if /when there might be a leak or defect in the blower's system that requires attention, because something is cheating you outa the boost you deserve...So, Mike, it's like the old American Express Card slogan: "don't leave home without'em"...
Old Jan 20, 2007 | 10:12 PM
Stangkiller's Avatar
Stangkiller
CI 5-6-7-8-9-10 Veteran
St. Jude Donor '07-'08
I use, fuel, boost, and AFR w/innovate wideband.
To using fuel and boost gauges
