Boost question.
Old Feb 5, 2007 | 05:32 PM
LAYNLOW's Avatar
LAYNLOW
Default Boost question.
In what increments can you change your boost with a pulley swap?
I'm running 7lb's now, can I go to 8lb or do I need to go to 10lb's, how does that work?
Thanks!
Old Feb 5, 2007 | 10:03 PM
Mike04's Avatar
Mike04
That really depends on engine size, the SC you have and RPM. Usually a pulley change to the next size will increase about 2 lbs of boost.
What SC system do you have and what is you displacement?
Old Feb 5, 2007 | 10:17 PM
RocketSled's Avatar
RocketSled
Thanks!
I went from the stock 3.4" pulley on my Maggie to 3.2" to go from 5-6 psi to 7-8 psi at 6000' MSL.
I drove this way for three or four months then went back to the stock pulley. The _octane_ available up here couldn't sustain the boost without changes to the fuel map. I was getting severe retard due to knock.
So, it's not a one-variable situation. If you want more boost, you'll have to compensate with fuel and spark. If you're okay with that, good on ya!
Old Feb 6, 2007 | 05:46 AM
LAYNLOW's Avatar
LAYNLOW
I have the stock displacement of 350 ci. The more I read about the baggage that comes with the boost increase is certainly making me re-evaluate this. I think I'm going to wait until I can do this the right way or just leave things as they are.
Thanks to everyone who responded!
To Boost question.
