MAF Question.
Old Feb 14, 2007 | 01:20 PM
Y2KRoadster's Avatar
Y2KRoadster
Default MAF Question.
Hello I currently have the stock ZO6 MAF on my 2001 coupe. The car has a built engine and I am currently at 540RWHP on 8 PSI. I am going to bump it to 12 PSI and add meth which will bring the HP to around 650RWHP. My question is, will the ZO6 MAF be able to support this kind of power. I am tuning with EFI live. Thanks!!
Old Feb 15, 2007 | 05:59 AM
EPP's Avatar
0EPP
Former Vendor
The maf will be maxed out, but you can tune for it without having any problems. We use EFILive as well, give us a call and ask for Brent, and he can help you out. 260 244-4808. Bob
Old Feb 15, 2007 | 11:50 AM
INTHERED's Avatar
INTHERED
I would think that your MAF is maxed out already if you rev above 6000 rpm. What size injectors are you using ? If they are the Ford 42# ones then they are close to being maxed out too.
Old Feb 15, 2007 | 09:33 PM
Y2KRoadster
No I have 60LB injectors.
Old Feb 15, 2007 | 09:34 PM
Y2KRoadster
Hey thanks a lot Bob, I will give Brent a call in the morning.
Old Feb 16, 2007 | 07:06 PM
leojnknsC5's Avatar
leojnknsC5
The 2004 MAF will max at 10 psi. And the MAF housing will split at 12.
Old Feb 16, 2007 | 07:15 PM
RoadRebel's Avatar
RoadRebel
MAFs max out based on flow, not "boost presure".
While there is the ocasional MAF failure at elevated levels most compostite MAFS hold up well. I personally have tune 50+ boosted cars with 12+ psi and no failures. A lot of the failures I have seen appear to stem more from how they are installed with poor alignments etc putting a side stress on the plastic housings.
Phil
Old Feb 16, 2007 | 08:48 PM
Y2KRoadster
Oh okay. Then the stocker SHOULD hold up at 12 psi and alky (don't know if the alky matters) as long as it is aligned up correctly and the tuning is good?
To MAF Question.
