Relationship between temperature and fuel pressure.
Old Mar 8, 2007 | 12:29 AM
LV Vette's Avatar
LV Vette
St. Jude Donor '08
Default Relationship between temperature and fuel pressure.
On a cool day (45-55*), my fuel pressure gauge reads about 62lbs. at idle and goes down to about 59lbs at full throttle. On a warmer day (70-85), the pressure is about 60lbs. at idle and goes down as much as 56lbs at full throttle. Is this normal? And just how does temperature relate to fuel pressure. Also, should I get a boost-a-pump or something similar to be on the safe side?
Thanks,
Clayton from Las Vegas
Old Mar 8, 2007 | 12:02 PM
LV Vette's Avatar
LV Vette
St. Jude Donor '08
WOW,
20 views and nobody has a response. Did I stump you all?
Old Mar 8, 2007 | 12:08 PM
MIKE-C5's Avatar
MIKE-C5
St. Jude Donor '05-'06-'08
Default Fuel Temperature
The person you need to get advise is diynoob (Tony) He knows all about fuel temperatures..................
Good Luck!
Old Mar 8, 2007 | 12:24 PM
Mike04's Avatar
Mike04
My car was similar to what you are describing as the temp increased. If your tune takes into acount the fuel pressure falling of you should be OK. Getting a boost a pump would be a good idea. I ended up going with the ECS fuel system. The boost a pump didn't help my pressure out enough to give me a warm fuzzy about the pressure. Now I am at 60lbs at all RPMs and temps.
Old Mar 8, 2007 | 12:26 PM
Tony @ MPH's Avatar
Tony @ MPH
Supporting Vendor
As fuel temp increases, your pressure will decrease a bit. Going down to 56psi at WOT is probably nothing to be alarmed at if your tune was done with the car warm and your air/fuel is still good at 56psi (which it likely is).
Ask your tuner how your car was setup. It was likely tuned with enough fuel to account for small changes in pressure.
Old Mar 8, 2007 | 01:18 PM
Sigforty's Avatar
Sigforty
Cruise-In IX Veteran
where is the pressure gauge located? The C5 fuel system on 01's and later have a pressure regulator in the rear of the car. This means that when the gauge is in the front of the car by the rails you will see more drastic pressure drop as the fuel is being pumped from front to rear. as for the tempurature changes in pressure it has to do with the rising vapor pressure of the fuel. The rise in vapor pressure changes the density of the gasoline making it a lighter component. It is normal to see movement of the pressure to about 5-10 PSI in the system.
Old Mar 8, 2007 | 02:42 PM
C_Williams@RPM's Avatar
0C_Williams@RPM
Former Vendor
Thanks,
Heat in fuel (liquid) lowers the specific gravity.
If you are running without a boost a pump, add one.
Charlie
Old Mar 8, 2007 | 07:08 PM
SudburyC6's Avatar
SudburyC6
Somebody should make a pump that is temperature and pressure compensated....
To Relationship between temperature and fuel pressure.
