Upgrade Path? Suggestions
Old Mar 18, 2007 | 05:38 PM
Hool97's Avatar
Hool97
Default Upgrade Path? Suggestions
So i want to go a little bigger and badder. 427ci P1sc-1 3.6" pulley running 7-9 psi. AFR 225 heads compression is about 9.4:1. I have Andy's bracket.
I would like about 100more HP. So 725-760 rwhp.
I have a stndard 6 rib. Yah i know.
I was looking at just upgrading to the D1 but this would likely put it in the same place as the P1, ie 3.6" pulley at max rpm.
The other path would be to get an F1A and pulley down. Just don't know how big the pulley would be . Likely 4.1" or 4.2".
The other way would be to get an F1C but i do not know if it would fit Andy's bracket. Also running it at 725-750 rwhp may be a little low in its efficiency range.
Any suggestions?? Also is the noise that big of a difference between the units?
I am also going to low imp. injectors to improve idle with big injectors.
Also a 100000 btu fluidyne oil cooler is going in.
Old Mar 18, 2007 | 05:51 PM
mdhmi's Avatar
mdhmi
F1A + 8 Rib
Old Mar 18, 2007 | 06:28 PM
Skunkworks's Avatar
Skunkworks
Don’t know how much this will help… but when you look up specs on D1SC and F1A you’ll notice impeller inlet area increases (which indicates more target flow) but diameter is reduced thus requiring to be spun harder.
Don’t have any long term reports on how belt survives on F1A versus D1SC. If impellers where close to each other, then nod would go to F1A do to larger gearing stepup which intern would allow larger pulley thus more contact area.
Mike
EDIT --- F1A will work with your bracket but F1C will not.
Old Mar 18, 2007 | 07:41 PM
peter pan's Avatar
peter pan
Life Time NCM #2196
With the cubes you are running there is no reason to not goto the F series head unit. My little 346 puts down the power you are looking for with Andys orginal bracket and the DS1C head unit. I see 14 lbs at 6200 and a little more at 6800 and very seldom to I shift above 6k no reason to just beat on it as I have all the power for my current needs
Old Mar 18, 2007 | 09:59 PM
Hool97's Avatar
Hool97
Thanks for the replys so far. I am leaning towards the F1A and later a 8 or 10 rib set-up if i want to go beyond 750 rwhp.
So the bolt pattern on the F1c is different than the F1A?? as per Mike at Skunkworks.
Thanks everyone!!!
Old Mar 19, 2007 | 01:07 AM
jbsblownc5's Avatar
jbsblownc5
2017 C5 of the Year Finalist
St. Jude Donor '08
The 8 rib belt will make a big difference if you want more power!!
Good luck Buddy!
JB
Old Mar 19, 2007 | 06:32 AM
EPP's Avatar
0EPP
Former Vendor
I wouldn't upgrade the head unit without changing over to the 8 rib pulley assembly. I can almost guarantee that you will have belt slippage problems. Bob
Old Mar 19, 2007 | 01:53 PM
Hool97's Avatar
Hool97
Thanks JB,
I am getting the picture, thanks Bob (EPP)
Old Mar 19, 2007 | 02:17 PM
peter pan's Avatar
peter pan
Life Time NCM #2196
Good luck Buddy!
JB
That is the way to go, I am start seeing belt slip at 6200 on my setup, preventing me to go for more until I decide on the 8 rib, but with me not being a 1/4 guy I will wait until this belt wears out on my street car
Old Mar 19, 2007 | 05:52 PM
Hool97's Avatar
Hool97
I talked to procharger and they said that the f1c and f1r would bolt up but would require additional mounting points. They said the one thing to watch out for is clearence.
From what they have also told me i can't see going with the F1c or f1r unless drag racing. They guy told me if i see 10# with the p1 then it will be about 14-16# on a D1 and 20-22# on a F1A with the same size pulley. You imagine getting north of 1.5 bar now thats 1000rwhp+.
Now i wonder what size of pulley to get. again not i am not trying to push-it right now.
Suggestions for 60-100hp gain?? 5", 4.75" OR 4.5"
the tep up 5.4:1 does help.
Old Mar 19, 2007 | 08:03 PM
Rkreigh's Avatar
Rkreigh
how about that cool new pulley with the "one way" sprag. it's a cog drive setup but designed to allow backlash for street driving.
probably expensive, but I'm curious if there is any "mileage" on this setup or anyone has experience with it looks like a sharp idea to me.
with a mongo blower, you are putting alot of torq through that belt and shedding them is a bummer.
Old Mar 19, 2007 | 08:28 PM
Jeff @ TPE's Avatar
0Jeff @ TPE
Former Vendor
St. Jude Donor '06 & '12
I had an F1-R on my 346, and it was VERY streetable. As a matter of fact, I felt it was more streetable than the D1.
I would opt for the F1-R and 8 rib pullies. You will be wasting your time going with a larger head unit and not changing your pullies out.
Old Mar 20, 2007 | 04:41 PM
Hool97's Avatar
Hool97
Yah the 8 rib will go in with the blower. Thanks
But any idea what pulley to start with??
see previous post for gains wanted.
To Upgrade Path? Suggestions
