boost gauge help install
Old Mar 23, 2007 | 01:03 PM
duvall408w's Avatar
duvall408w
Default boost gauge help install
Just trying to figure out were to install the boost hose? I really dont want to take the intake off and i seen some say the anti surge valve. It currently has a d1sc on it where would the surge valve be at? Or is there any were else to hook it up at thanks robert
Old Mar 23, 2007 | 02:08 PM
Cajundude's Avatar
Cajundude
Active Streak: 90 Days
Cruise-In 7-8-9-10 Veteran
St. Jude Donor '06-'07-'08-'09-'10-'11-'12
T off the vacuum line at the brake booster.
Old Mar 23, 2007 | 02:22 PM
C5VERTMAN's Avatar
C5VERTMAN
Old Mar 23, 2007 | 02:51 PM
E.A.'s Avatar
E.A.
You can do it off the brake booster.
Or you can just get a good "t" and find the small vacuum line (tiny 1/4" line) that operates the bypass valve. This line will run from the valve, up to your intake manifold. It will be easy to find. It's a small device mounted to one of the discharge tubes in the front nose of the car.
Should look something like one of the following.....
The silver one in this photo, yours could be black.
http://www.procharger.com/images/art...ass_valves.jpg
If you have a Vortech one for some reason.
http://www.seanhylandmotorsport.com/.../8D204-001.jpg
Or maybe this,
http://focus.c-f-m.com/ProductImages/cfm-FMCL007Ps.gif
Old Mar 23, 2007 | 05:09 PM
Mike04's Avatar
Mike04
To boost gauge help install
