Its alive!
Old Mar 25, 2007 | 03:52 AM
FactoryRaceCar's Avatar
FactoryRaceCar
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12
Default Its alive!
Not my car but a buddy of mine who is on vacations these days
Clicky!
His message "I am ready! Are you?!?!"
Old Mar 25, 2007 | 04:30 AM
mdhmi's Avatar
mdhmi
That wouldn't happen to be an F1 with an auto conversion would it?
Old Mar 25, 2007 | 04:31 AM
FactoryRaceCar
Old Mar 25, 2007 | 08:56 AM
99 C-5 F1C VETTE's Avatar
99 C-5 F1C VETTE
American Killer!!!!!!!!!!!1
Old Mar 25, 2007 | 09:39 AM
MIKE-C5's Avatar
MIKE-C5
St. Jude Donor '05-'06-'08
Default Wow
Aaron's Car is sure loud..............
Old Mar 25, 2007 | 10:03 AM
Max@Cartek's Avatar
Max@Cartek
Love it. Sounds nice.
Old Mar 25, 2007 | 11:09 AM
BUBBAS 01Z06's Avatar
BUBBAS 01Z06
Way to go Arun !!
Old Mar 25, 2007 | 11:12 AM
Tony @ MPH's Avatar
Tony @ MPH
Supporting Vendor
Sounds awesome!
Old Mar 25, 2007 | 12:37 PM
FreddyG's Avatar
FreddyG
You got me Nouman! I thought that by the heading that yours was finished! I was smiling for you!
That's one loud blower! Though it is one SWEET looking setup and I'll bet it'll haul the groceries..........especially with the A4! Congrats Arun!
Old Mar 25, 2007 | 01:04 PM
Z_Rocks's Avatar
Z_Rocks
a) Is it 6-rib or 8-rib
b) What's the size of pulley
c) How is it that it makes boost so fast, while revved it from idle to 3K and I see the boost was jumping almost 7-8psi?
d) What's the max PSI set for it?
The engine sounds very responsive!
Old Mar 25, 2007 | 01:47 PM
B-rent's Avatar
B-rent
I had that my Vortech has the quite s/c on it
sounds good though
Old Mar 25, 2007 | 02:24 PM
Max@Cartek's Avatar
Max@Cartek
Some of the reasons it builds boost faster than normal is:
-The step up ratio on the F1 is 5.4 vs. the 4.1 of the P1 and D1SC
-The effect of having a large head unit on a 347.
Mine was exactly the same way. It was instant... and tons of fun.
Old Mar 25, 2007 | 02:44 PM
FRCTony's Avatar
FRCTony
Old Mar 25, 2007 | 04:23 PM
99 C-5 F1C VETTE
I run a 382 F1R 10 RIBBER, DUAL NOZEL METH INJ, WHENT WITH THE TEN RIB BECAUSE MY 8 RIB WOULDNT HOLD 12PSI , CHANGED TO ECS BRACKETS GOING FOR 15 PSI........
Old Mar 25, 2007 | 04:32 PM
NemesisC5's Avatar
NemesisC5
Damn, that beast REVS FAST ! !...I need a De-Stroked LS7 with F1R
Old Mar 25, 2007 | 06:48 PM
Hool97's Avatar
Hool97
Yah, more details.
Did he drill out the bracket or get a new one from the D1->F1R. There are additional mounting holes.
Old Mar 25, 2007 | 07:10 PM
MotleyDrew's Avatar
MotleyDrew
Arun looks good bud ! How come the boost gauge is reading any boost when the car is in park and not under load ????
To Its alive!
Old Mar 25, 2007 | 08:16 PM
FactoryRaceCar
Default Some info on Arun's setup
"It’s an 8 rib, 8” crank 4.13 blower pulley,
Max boost-who know’s? I can go down to a 3.65 pulley before the blower’s maxed out( NMRA Renegade spec 5.0 stepup 74000 rpm)
The reason your seeing boost is just what Cartek Max said. It’s just a little 347 with a big blower.
The blower flows 2000cfm compared to the 1400 that the D1 did. The bypass is struggling to get the air out-it has one Greddy Type R heavy spring ( 1-7/8 piston)-might have to add another one.
Another reason is the belt isn’t slipping either-I fabbed up some custom idlers to get max contact area on the belts."
Old Mar 25, 2007 | 08:28 PM
STEALTH 99 C5's Avatar
STEALTH 99 C5
Sounds strong .
Old Mar 25, 2007 | 08:39 PM
MotleyDrew's Avatar
MotleyDrew
this is the one I am using, should do the trick for Arun's aswell !
http://www.vortechsuperchargers.com/product.php?p=23
