Do LS7 heads require special long tubes
Old Mar 28, 2007 | 07:32 PM
LS7 C5's Avatar
LS7 C5
Default Do LS7 heads require special long tubes
I am having an LS7 built to put in my 2000 C5, I will be using C5 oil pan.
Does anyone know if it will require special LT headers to fit the heads or will any LT headers for a C5 work.
If it does require a LS7 specific header anyone know who might make them?
Old Mar 28, 2007 | 07:59 PM
DBN's Avatar
DBN
No. I don't think that you need a special header just because of the LS7 engine, however, you might want to go with a larger diameter tube such as 1-7/8". If you are going to buy a new set, I recommend American Racing Headers.
Old Mar 28, 2007 | 09:45 PM
LS7 C5's Avatar
LS7 C5
thanks, I wasn't sure if the exhaust ports were different on the LS7 heads
Old Mar 28, 2007 | 10:27 PM
RoadRebel's Avatar
RoadRebel
Well, the answer is usually YES. Most headers on the market do not have the flange port high enough to not block the top of the exhaust port. Even the L92s hit.
Phil
To Do LS7 heads require special long tubes
