Meth injected??
Old Apr 3, 2007 | 07:31 PM
jzemo's Avatar
jzemo
Default Meth injected??
How many of you guys running a meth kit? I've been looking around, Snow performance has a kit, does anyone run this? Are there any others out there? How hard is installation? Power gains?? Is meth going to be compatable with a H/C?? What other things would I need to install if I went with the meth kit?
Old Apr 3, 2007 | 07:42 PM
robsciam's Avatar
robsciam
i have a esc meth kit on my procharged zo6. call east coast superchargers, from what i hear its one of the best.
Old Apr 3, 2007 | 11:25 PM
jzemo's Avatar
jzemo
anyone else have an opinion??
Old Apr 4, 2007 | 12:13 AM
Pakisho's Avatar
Pakisho
Yup, Ive got the ECS kit, which is done by Julio at alky control, supplied by Synergy and installed by OC Corvette.
Damn, wonder if I could have involved a few more vendors in that one!
Works great, I like knowing I can rail the car in the heat and actually have the intake temps drop.
Old Apr 4, 2007 | 12:26 AM
jbsblownc5's Avatar
jbsblownc5
2017 C5 of the Year Finalist
St. Jude Donor '08
I run Julio's Alkycontrol kit as well!! I've had great results over the last 2 years!
JB
Old Apr 4, 2007 | 01:25 AM
RHP's Avatar
RHP
Default meth
I'm running a Snow performance meth kit on my Vortech boosted Z06. I bought the kit without much research, but it's served me well for the past couple of years. Snow has done well, I had a bad pump and they replaced it. If I have any problems again, I'm going to go with the Alky Control kit. JUILO KNOWS MORE ABOUT METH INJECTION THAN ANYONE!
Julio took the time to talk meth with me even though I had another kit. This man is 100% character and integrity.
Roger
Old Apr 4, 2007 | 01:32 AM
Tony @ MPH's Avatar
Tony @ MPH
Supporting Vendor
Julio is definitely a stand up guy, and he knows his stuff.
Old Apr 4, 2007 | 05:11 AM
Vince99FRC's Avatar
Vince99FRC
I run the ECS dual nozzle kit... I feel you need everything possible to protect your investment.
Old Apr 4, 2007 | 08:16 AM
Rob's 73's Avatar
Rob's 73
ECS kit here. Install is easy if you follow cajundude's install instructions.
Old Apr 4, 2007 | 08:50 AM
FactoryRaceCar's Avatar
FactoryRaceCar
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12
JB
Me too
Old Apr 4, 2007 | 09:08 AM
E.A.'s Avatar
E.A.
I have no experience yet with the ESC Kit....(yet)
But last night we did just wrap up a SNOW Performance Kit. For my best friends car that has been dying for it.
Install took just a couple hours. (counting all wires being soldered, and heat wrapped) Nice easy 3 wire installation even with the boost/pump controller. Set the pump to come on at 5psi, and start ramping in the meth as she works her way up to 28psi of boost.
Likly one of the "best mods" of the last couple years that everyones been coo koo about. Easy to install, Cheap, easy to test prior to use, and great performance results.
From what the owner of Snow Performance has told me. They are actually about to get a new kit out. That will work with the factory computer, and look sensors like MAF voltage, as well as throttle position, to inject the correct amount of Meth...... now tell me that isn't cool.
EA
Old Apr 4, 2007 | 09:33 AM
peter pan's Avatar
peter pan
Life Time NCM #2196
I am using the older single nozzle ECS kit for the last 2 years and love it and Juilo is always available for tech support when setting or tweaking the setups
Old Apr 4, 2007 | 10:20 AM
SteveDoten's Avatar
SteveDoten
Cruise-In VII Veteran
just ordered the 5th ECS/Julio meth kit for this season yesterday from Chris, no other kit has as much C5 specific R&D, not even close
watch what happens to the smurf blue fisher price lines on the other kits after a year or so
Old Apr 4, 2007 | 12:10 PM
Mike04's Avatar
Mike04
I gained close to 40rwhp by using the kit as a power adder.
Old Apr 4, 2007 | 12:12 PM
bernrex's Avatar
bernrex
EA
Progressive controller function .....
Just what the Meth addicts need
Old Apr 4, 2007 | 12:27 PM
E.A.'s Avatar
E.A.
I just got off the phone with Matt owner of Snow Performance, and grabbed a kit for my Vortech car. (About time, I been lazy)
Matt said that as of Jan. 2007 alllllll of their parts are 100% meth compatible. They can be soaked and stored in 100% meth, or run dry as well. With absolutely no ill effects.
The pumps they are now using are built specific for them from Shur-Flow. Both for the Psi levels, and the fact of running 100% meth. ( Standard Shur-flow pumps can be bought at graingers, but I knew something was different about the ones they were using )
He said the only reason why his website, and product stuff dictates using a 50/50 mix is the following.
1) His insurance won't cover him stating to run 100% meth due to flammability reasons.
2) Most people don't need anymore then a 50/50 mix, and it helps him diagnose tuning issues over the phone easier, by keeping things consistent (or trying to)
3) If your fittings leak, with 100% meth, and spray gets near something Hot...... well, it's ALLLLL over, cause then you got a nice fire on your hands.
Well, thats all.....just figured since I just got off the phone with him, I would throw that up here.
Good day,
EA
To Meth injected??
