TT kit = pinned crank?
Old Apr 7, 2007 | 01:27 AM
AustinL911's Avatar
AustinL911
Default TT kit = pinned crank?
Should I go ahead and pin the crank while I'm putting on my TT kit? It was brought to my attention that even though I don't have the extra strain on the pulley from a supercharger, I will have the extra torque that could potentially loosen the crank bolt.
Good idea, bad idea?
p.s. Stock LS6 bottom. I will be tearing it apart anyways to replace the 3 problematic cam bolts with loc-tited ARPs.
Old Apr 7, 2007 | 01:31 AM
Fastbird's Avatar
Fastbird
Pro Mechanic
C5 of Year Finalist (performance mods) 2019
2017 C5 of the Year Finalist
2016 C5 of the Year Finalist
2015 C5 of the Year Finalist
It could be beneficial, but fwiw, I didn't have mine pinned with my TT kit.
Old Apr 7, 2007 | 01:33 AM
Skunkworks's Avatar
Skunkworks
I see no reason to as it’s not a power take off for power adder. The extra torque has nothing to do with accessories so skip it as its not needed.
Mike
Old Apr 7, 2007 | 01:40 AM
Tony @ MPH's Avatar
Tony @ MPH
Supporting Vendor
No pin here, but with 720+rwhp my belt definitely slips on the accessories. On the dyno you can see the underhood light go real dim
Old Apr 7, 2007 | 01:46 AM
Mr. Big's Avatar
Mr. Big
St. Jude Donor '07-'08
spun mine off twice with no pin in the crank. Ever since i pinned the crank, no more problems. Definatly worth it!!
Old Apr 7, 2007 | 01:50 AM
Skunkworks's Avatar
Skunkworks
I always knew you were going through supercharger withdrawal and even your car is letting you know.
Mike
Old Apr 7, 2007 | 01:53 AM
AustinL911's Avatar
AustinL911
Yea, a friend of mine on here (SprayedC5) was having horrible trouble trying to keep his on. He has a sprayed 402 that apparently didn't get along with it's crank bolt, as it was constantly trying to give it the boot. He pinned his and the problem went away.
Where's the best place to pick up a pinning kit? I'd rather do it and not need it, then need it, and not have done it....
....or something like that.
Old Apr 7, 2007 | 02:02 AM
Tony @ MPH's Avatar
Tony @ MPH
Supporting Vendor
Mike
Hahaha, no SC withdrawal until I start using up my AAA tows again for belt snap/ripping issues.
Old Apr 7, 2007 | 02:06 AM
1%r's Avatar
1%r
St. Jude 15 Year Donor
St. Jude Donor '03 through '17
I'm pinned and sometimes she pins me against the wall and I never complain.
Old Apr 7, 2007 | 02:23 AM
MIKE-C5's Avatar
MIKE-C5
St. Jude Donor '05-'06-'08
Default Pin Crank
I would, just an extra insurance!
Old Apr 7, 2007 | 04:51 AM
leojnknsC5's Avatar
leojnknsC5
If you pin it now, you'll have problems later if you decide to replace the balancer cause you'll have to redrill for the new one.
Old Apr 7, 2007 | 04:56 AM
FactoryRaceCar's Avatar
FactoryRaceCar
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12
Old Apr 7, 2007 | 08:01 AM
BLOWNZO6's Avatar
BLOWNZO6
Premium Supporting Vendor
If the pulley is off, I pin them. Cannot hurt.
__________________
EAST COAST SUPERCHARGING SALES AND TECH SUPPORT
WWW.EASTCOASTSUPERCHARGING.COM
Old Apr 7, 2007 | 11:10 AM
MotleyDrew's Avatar
MotleyDrew
Why is this a problem???? Pin it if its off. Its easy and chevy should have keyed these from the factory !
Old Apr 7, 2007 | 11:39 AM
AVB's Avatar
AVB
Think of what you'll have to go through if you need to get back in there after-the-fact. Any % chance it can happen is reason enough.
Arnel
Old Apr 7, 2007 | 12:15 PM
Vince99FRC's Avatar
Vince99FRC
Another vote for pinning the crank. Mine is pinned.
Old Apr 7, 2007 | 12:17 PM
M_T_0's Avatar
M_T_0
been there, done that, and it is no problem at all compared to getting back in there to replace a balancer. pin that B!^@# and be done with it.
More Than Zero
To TT kit = pinned crank?
Old Apr 7, 2007 | 12:31 PM
Rob@ChampionMotors's Avatar
0Rob@ChampionMotors
Former Vendor
Same here. Once @ Phil's (Road Rebel) and after getting back spun off again in about 500 miles. The problem is when you spin the tires hard with the rpm shooting up so fast the accessories can catch up and adds tremendous load. Pinned it no problems since.
Old Apr 7, 2007 | 04:24 PM
AustinL911's Avatar
AustinL911
Best place to get a pinning kit?
A&A? ECS?
Old Apr 7, 2007 | 04:31 PM
king_pin's Avatar
king_pin
St. Jude Contributor
Mine came off on the Dyno while Phil was tuning
