I am installing nitrous on my 2001 C5 vert. I have bought a duel piller pod, Dyna tune wide band, Dyna tune nos control gauge, C-5 Kidd custom duel gauge console, nos pressure gauge, fuel pressure gauge, Raptor shift light, Nitrous Dave's digital window switch, timing tuner, dedicated fuel system, TNT power ring system, purge kit, low fuel pressure safety switch, bottle warmer, and bottle opener.
I am looking for info on installation. best location for control boxes and relays, best place for shift light, best place for purge, best way to wire this up. Any help would be appreciated
Thanks Kris
You may want to venture to ls1 tech forum and read some of their nitrous posties to help you sort through the install. They have everything from wiring diagrams to pics to help you out. Once you get it installed you'll never look back! Good Luck.
I have some pics in my web site, then in the links section is some how to installs. Search this section also, and like was said check ls1tech. maybe start with some single questions, your asking for a whole lot of info in one post. Good luck
Robert
