Help with boost gauge install
Old Apr 18, 2007 | 02:21 AM
midnightc5's Avatar
midnightc5
Default Help with boost gauge install
Before tackling this task, I was wondering what would
be the best place to tee into for the boost line and where
the best location is to enter at the firewall? TIA for any
suggestions.
Old Apr 18, 2007 | 02:28 AM
2004SpiralGrey's Avatar
2004SpiralGrey
I was able to snake the boost line through the same opening where the hood release cable goes through. I cut the hose coming from the power brake booster and put the tee on there. If your running a BOV you can also tee it off of the line running to that. I hope that helps.
-John
Old Apr 18, 2007 | 02:42 AM
FactoryRaceCar's Avatar
FactoryRaceCar
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12
Mine is "T"ed in my BOV line along with KB BAP and Alky
Old Apr 18, 2007 | 01:41 PM
duvall408w's Avatar
duvall408w
Default brake booster
tee in to brake booster line
Old Apr 18, 2007 | 01:46 PM
MIKE-C5's Avatar
MIKE-C5
St. Jude Donor '05-'06-'08
Default Boost Gauge
Just T it up at the Brake Booster, thats where mine is. You actually have few places to run it inside through the firewall.
Old Apr 20, 2007 | 02:27 AM
midnightc5's Avatar
midnightc5
Successful install! Thanks for the help guys...
Old Apr 23, 2007 | 12:59 PM
1fstc5vette's Avatar
1fstc5vette
I'm going to T off the brake booster when I install my gauges since I'm boosted now, but I'm interested if you have pics or where you put it through the firewall
Old Mar 22, 2008 | 08:33 AM
valdeztke's Avatar
valdeztke
Old Mar 22, 2008 | 08:36 AM
madmatt9471's Avatar
madmatt9471
From: Palmdale, Ca----- 2009 Cyber Gray 4LT A6 F55 452 RWHP 422 RWTQ- RIP 1998 C5 734 RWHP & 585 RWTQ-----
I slipped mione in throught the same hole as my hood release cable! Worked out well!
I used a chaser wire to poke throuh and then I taped it to that and slowly pulled it through into the cab!
Thanks,Matt
Old Mar 22, 2008 | 09:16 AM
PeteZ06's Avatar
PeteZ06
St. Jude Donor '07-'08-'09-'10-'11
Thanks,Matt
Ditto.
I used an old metal hanger and taped the gauge leads to it and shoved it through.
Old Mar 22, 2008 | 09:36 AM
vetterlatethannever's Avatar
vetterlatethannever
I missed the date teh first time and thought you pulled it off in 6 minutes Congrats!!!
Old Mar 24, 2008 | 09:53 AM
zr1John's Avatar
zr1John
Default Boost Gauge
Here's another question about installing your boost gauge. Where do you tap into the dash lighting circuit with the gauge so that it lights up when you turn your lights on??
Thanks.
Old Mar 24, 2008 | 09:58 AM
philsy's Avatar
philsy
I did not wire mine into the lights I did not want to play with the harness I just picked up power in the passenger side fuse panel (keyed hot) there are a few places in the panel to get the power with out haveing to tap into the harnesses.
To Help with boost gauge install
