Dynotune Window Switch Programming
Old May 6, 2007 | 03:29 AM
smokinrt2001's Avatar
smokinrt2001
Default Dynotune Window Switch Programming
Hoping someone can help me out here......Just trying to dial in my window switch and need a little help...
Under the tach set up part(1)
What do I enter for an 02 LS1?
also on step 5.....its for stage two.......since i didnt hook it up(I left the orange wire alone) what should i enter ?
Step 8.....I floored it and it then read 4.8 that sound right ?
Please reply if you have any help with my questions.......Thank you in advance.
Old May 6, 2007 | 03:53 AM
Beer99C5@FastbirdPerf.com's Avatar
St. Jude Donor '08
Tach set up from the coil pak 00, from the PCM wire I think its 4 cyl 04. To check the rpm AFTER its set up press and hold the first button at idle and it should read 06 or 07 for 600-700 RPM
Orange wire do not cut it just coil it up out the way (keep the switch resale value), and I would tape up the end and set it for say 7000 RPM-8000 off (your not gonna use it, DO NOT set it for 0).
Step 8 yes sounds good for the TPS
Sounds like your ready to go
Old May 6, 2007 | 04:05 AM
smokinrt2001
ok i think im good then...........first part is the only thing that really confused me......in the instructions it was a bit confusing ill check it out tomorrow........just need to change the plugs tomorrow and its go time
Old Jul 7, 2007 | 01:41 PM
imflyinbiya's Avatar
imflyinbiya
I am about to install as well.
So TPS and Coil packs just like above on my 03z06? Also, where are you guys getting your switched 12v from? There is a hot pink wire on the drivers side of the dash that I think will work. Are you running relays?
Thanks!
Old Jul 7, 2007 | 06:22 PM
St. Jude Donor '08
Thanks!
I am running relays for Heater, Wet and Dry stages.
Power I got from a factory pigtail that is unused in the passenger footwell.
Not sure if the 03-04 ZO6's had this Pigtail, it is pictured above in the Black Factory Duct tape.
To Dynotune Window Switch Programming
