Does this PCV look ok?
Old May 9, 2007 | 11:32 AM
95BlueBomber's Avatar
95BlueBomber
Default Does this PCV look ok?
The first picture is for an LS6 that has the galley hose. The second is a 98 LS1 without. I have little stainless breathers to go on the back of the valve cover on the drivers side. I cant remember if the 99 has that port or not. Does this look ok to you guys? I will be blocking off the throttle body port. Any input would be great!
Old May 9, 2007 | 12:42 PM
AVB's Avatar
AVB
There's a lot of information regarding PCV setups... check them out via a search.
Your diagram shows the crankcase vented. If your objective is to only prevent a pressurized crankcase this will work although you could probably accomplish the same without the second breather.
Arnel
Old May 9, 2007 | 01:09 PM
95BlueBomber
Arnel
I searched for a good diagram of what I have, and cant seem to find anything. What would be your recommendation?
Old May 9, 2007 | 02:33 PM
Warp Factor's Avatar
Warp Factor
The downside is that you appear to have eliminated the vacuum source, so you no longer have positive crankcase ventilation. There's no pressure differential feeding fresh air into the engine.
As Arnel said, if you just want to vent the crankcase, I don't see the value of the second small breather.
Old May 9, 2007 | 04:35 PM
95BlueBomber
I changed the pic... does this look any better?
Old May 9, 2007 | 04:47 PM
Warp Factor
There is currently no picture, and it won't pull up from the "page source" address.
Old May 9, 2007 | 06:01 PM
AVB's Avatar
AVB
As mentioned, if you are wanting to vent the crankcase and delete the PCV then that's fine. Removing the second breather would make things nice and clean.
IF pulling nasty vapors is important then..
let's just say your going to pull blowby from a single point on each valve cover. The OEM vacuum source is the intake manifold through the PCV... if used, it will need to be protected of oil being sucked into it via a separator or catchcan. It is important that the catchcan being used is separating or baffling between the ports hooked to the crankcase and the intake (vacuum source). Also, between the catchcan and the vacuum source should be a checkvalve (inplace of the PCV) that only allows air to enter the intake and never the other direction (as would be happening when in boost if no checkvalve is present).
Some folks will allow a little bit of air to enter the crankcase so that too much vacuum isn't built up in the crankcase. This is done via a filtered, controlled, incoming leak (right about where you show the second breather).
Arnel
Old May 9, 2007 | 09:33 PM
95BlueBomber
Default Is this too simple?
Does this work or is this way too simple?
Old May 9, 2007 | 10:01 PM
Warp Factor
A really common setup is to use a breather (such as the ECS breather) at the oil filler, and a non-vented catch can between the valve cover and the intake.
I use the PCV valve as a check valve, but some people don't like that idea for reasons I don't understand.
Old May 9, 2007 | 10:13 PM
95BlueBomber
Does what I have shown there work though?
Old May 9, 2007 | 11:26 PM
AVB's Avatar
AVB
If it were really that simple there would be the perfect setup and solution... that doesn't exist just yet
Your line to the intake needs a catchcan. it goes like this... crankcase (this could be anything pulling from the crankcase but large enough to keep pressure from registering in the crankcase at the highest levels of blowby. Could be valley cover but easier to put a larger fitting at a valve cover) then checkvalve then intake.
Arnel
To Does this PCV look ok?
