Quaife Differential ???
Old May 12, 2007 | 11:43 AM
2004SpiralGrey's Avatar
2004SpiralGrey
Default Quaife Differential ???
I received the new Vette magazine and in the product preview section it has a Quaife Diff. by Unitrax. I've heard good things about them in the past in many imports and other vehiciles. I was wondering if anyone was running one in there car?
They go for about $1,650. Their are no clutches in the unit it is gear operated. It also comes with a limited lifetime warrenty. I thought maybe I would post here and see if anyone has this unit in their car and could give some insight on how it is.
Thanks in advance,
John
Old May 12, 2007 | 12:31 PM
Tony @ MPH's Avatar
Tony @ MPH
Supporting Vendor
IB4TJB
I'm 99% sure this is the diff JB is running in his car. I may be hallucinating but I think his is even setup with a cooler somehow?
Old May 12, 2007 | 01:54 PM
2004SpiralGrey
Originally Posted by diynoob
IB4TJB
Thats good to know I'll PM him and find out...What does "IB4TJB" mean? I'm not a noob but I always see you guys typing that and don't know what it is...lol
Old May 12, 2007 | 02:02 PM
FactoryRaceCar's Avatar
FactoryRaceCar
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12
In before JBSBlownC5
Old May 12, 2007 | 03:04 PM
petercln's Avatar
petercln
Isnt this diff mainly used for roadracing? Not drag racing.
Old May 12, 2007 | 03:39 PM
jbsblownc5's Avatar
jbsblownc5
2017 C5 of the Year Finalist
St. Jude Donor '08
From what I was told by Unitrax, I got the first Unitrax/Quaife built 373 diff on a C5 In the world.
I've had a few diffs done by Unitrax, since my clutch pacs wear out every 15 months or so, just about the same time I rip a tooth or two out of my ring and pinion...
Since the quaife eliminates the clutch pacs, and does come with a lifetime warranty, Unitrax thought I was a good candidate to try it out on!
I've had no issues with it, and love the way it works!! It does allow nice hookup on exits out of the turns, and has held up great so far!
Unitrax worked with Orange County corvette on the install. Unitrax had the 373 gears machined a bit to accept the C6 Z06 rear cover for the diff. It has a built in pump, that Sean at OCC then hooked up to a cooler and installed the custom lines! The system works great, and keeps temps nice and cool on the track and canyon.
JB
Old May 12, 2007 | 03:59 PM
Skunkworks's Avatar
Skunkworks
The Quaife appears somewhat similar to GleasonTorsen (spelling?) in theory of operation. A friend had a GleasonTorsen in his race car and loved it, I did drive it on a few occasions and it does great out of corners (especially tight ones).
I’d say this is a great roadrace mod as noted above, not sure on drag applicability.
Mike
Old May 12, 2007 | 10:25 PM
Mean Gene55's Avatar
Mean Gene55
St. Jude Donor '08
Default Torsen Style
Mike
Mike - Yes, the Quaife is a Torsen based LSD. I installed one on my supercharged G35 & it was a GREAT addition! It was quiet ( as opposed to the NISMO LSD ) & allowed just enough "release" coming out of corners so that the car didn't want to push the rearend out. I was mostly a drag racer ( weird for an import, I know! ) but the Quaife worked well there also.
Gene
Old May 12, 2007 | 10:34 PM
rodney@rpmtransmissions's Avatar
0rodney@rpmtransmissions
Former Vendor
I have installed one in a differential I built for a customer(Billiardcue). Maybe he will chime in as well. I was impressed with the quality of the Quaffe and I know he really likes the operation of it. We have also installed a few of the differential pumps/coolers that Joel was talking about in his post.
Old May 13, 2007 | 02:51 AM
2004SpiralGrey
So what kind of power can the Quaife hold with hardened shafts?
Can it handle a set of nittos or BFG drag radials under hard launches?
JB- How long have you had yours in your car? Have you had to replace it at all?
Thanks,
John
Old May 13, 2007 | 06:20 AM
stevieturbo's Avatar
stevieturbo
Quaife defo make good stuff..although a bit pricey.
Fair enough I have a Live axle in my car ( 8.8" ), but I also use a Torsen diff...and it cost $500 a few years ago.. The US based stuff is just so damn cheap !!!
Which when it gets to me in the UK....is about £300 !!!! Its about 1/3 of the price of a Quaife unit.
So far Ive found mine veyr good for drag racing, and every day use.. But they do need both wheels to have some traction in order to work.
If one wheel goes very light or even airbourne, traction will be lost.
Some newer Torsen designs come pre-loaded so this doesnt happen. I'll be upgrading to one of these newer ones soon.
Odd that someone in the US doesnt offer a Torsen diff for you guys already ???
Old May 13, 2007 | 11:01 AM
Rickyh93's Avatar
Rickyh93
When I was helping build some high hp Civics the Quaife limited slips were about all that would hold the power besides the spools. They were about $900 for a fwd unit for the civic, we didn't have a ton of torque going thru it (I will have to find the sheet) but we had over 700whp going thru it with 28"x10" slicks with no problems.
Lifetime warranty doesn't matter if you race or not, gotta love that.
Old May 13, 2007 | 01:05 PM
2004SpiralGrey
I am looking to be putting down about 700 rwhp and when I come up with the money for the diff i think i am going to try and see how it is.
Old May 13, 2007 | 03:34 PM
jbsblownc5's Avatar
jbsblownc5
St. Jude Donor '08
Thanks,
John
I've not replaced it since install about 6 months ago. I put down over 700 RWHP, and run NT-01s, which grab real good!!!
I've launched pretty hard down low with no problems!! I believe, that my Unitrax/Quaife diff has hardened shafts on both sides...
JB
Old May 13, 2007 | 08:44 PM
NemesisC5's Avatar
NemesisC5
Joel, Has my brain been on vacation, or did you just increase your hp/tq numbers in your sig. Maybe that is what the other post is about
Old May 14, 2007 | 02:12 AM
2004SpiralGrey
JB
Thanks Joel...Looks like I'm going to try the Quaife after all
Old May 14, 2007 | 02:23 AM
jbsblownc5's Avatar
jbsblownc5
St. Jude Donor '08
I gave some info on the other post...
To Quaife Differential ???
Old May 14, 2007 | 01:30 PM
LV Vette's Avatar
LV Vette
St. Jude Donor '08
Anyone have a link to their website? I am curious to see what it looks like and more info on it.
Thanks,
Clayton from Las Vegas
Old May 14, 2007 | 01:41 PM
2004SpiralGrey
Thanks,
http://www.gounitrax.com/corvette.htm
Old Oct 21, 2008 | 07:36 PM
YO-EL's Avatar
YO-EL
Any drag race differences in your ET with the Quaife vs regular diff?
How are the burnouts, the launches, the 60'..????
