need rotors ?
Old May 20, 2007 | 01:46 AM
Carbotech Adam's Avatar
Carbotech Adam
Supporting Vendor
St. Jude Donor '11,'13
Default need rotors ?
rotors nedded for 500 rwhp car. what is everyone using?
Old May 21, 2007 | 11:46 AM
Independent1's Avatar
Independent1
St. Jude Donor '08
Unless you are roadracing your stock braking system is more than enough. Of course if you are into bling, you can buy some cross-drilled and slotted rotors but you won't stop any faster. Might even stop slower, since you have less effective rotor area due to cross-drilling.
If you want to read up about brakes do a search over in the roadracing/ auto-x section. Big topic over there.
Old May 21, 2007 | 11:07 PM
Vegas Vette's Avatar
Vegas Vette
Check out this site I run the Disc Italia the work great and look good too. I had them nickel coated also.
http://www.brakeworld.com/catalog.as...=items&catid=1
To need rotors ?
