Gatorback Belts
Old May 20, 2007 | 10:59 AM
Twin Screws's Avatar
Twin Screws
Default Gatorback Belts
I called Procharger about these belts, and even though there have been lots of positive reviews on the board that they are an ungrade, Procharger claims they are not. ANy thoughts?
Old May 20, 2007 | 11:44 AM
eb02z06's Avatar
eb02z06
St. Jude Donor '08
Stick with the Gates.
Old Apr 23, 2008 | 10:09 PM
Twin Screws
Spoke to Procharger again today....apparently they are changing their tune and claiming the Gatorbacks may be a cure for the squealing some of us have experienced on cold start ups with the Gates belts...
Old Apr 23, 2008 | 10:48 PM
madmatt9471's Avatar
madmatt9471
From: Palmdale, Ca----- 2009 Cyber Gray 4LT A6 F55 452 RWHP 422 RWTQ- RIP 1998 C5 734 RWHP & 585 RWTQ-----
I thought the same thing but decided to stick with GATES!
They are proven and a lot of FI fella's I have talked too have had some issues with the Gator belts!
NAPA sells Gates and they work excellent
Thanks,Matt
Old Apr 23, 2008 | 11:00 PM
bullitt4110's Avatar
bullitt4110
Thanks,Matt
I like to use the Gates belts on all of my FI applications.
Old Apr 24, 2008 | 01:50 PM
gorillavet's Avatar
gorillavet
Interesting...I have seen several comments of a negative nature regarding GatorBack belts. In four years of use I have never had even one issue, particularly due to slipping or noise. Perhaps I am just lucky but I know several other folks who run them as well with no issues.
Old Apr 24, 2008 | 02:30 PM
Twin Screws
Default Ati
I had a Gates, worked fine, other than nasty squealing when cold. ATI is now recommending the Gatorbacks as a squeal solution.
I would be curious to compare the setup/hp levels of those that have trouble and those that don't (with the Gatorback). A tuner I spoke with didn't recommend the Gatorbacks for high HP set ups (over 550-600rwhp). Under this, he said I would be fine?
Old Apr 24, 2008 | 03:45 PM
Z06PSI's Avatar
Z06PSI
St. Jude Donor '17-'18-'19
What about the Kevlar injected green belts from Gates?
Old Apr 24, 2008 | 04:00 PM
BLOWNBLUEZ06's Avatar
BLOWNBLUEZ06
Yeah, I took a set of those to the rifle range not long ago. They didn't hold up!!
gorillavet's Avatar
gorillavet
I have a little over 650 rwhp with a Gatorback and as I said no problems.
Old Apr 25, 2008 | 10:38 AM
MIKE-C5's Avatar
MIKE-C5
St. Jude Donor '05-'06-'08
To Gatorback Belts
