Oil temps and boost
Old May 26, 2007 | 06:54 PM
Laguna Blu's Avatar
Laguna Blu
Default Oil temps and boost
I took a 30 mile drive today with the A/C on and noticed that my oil temps hit 237 degrees, coolant at 230 and tranny at 225. This was 60 mph highway driving with little to no traffic. When I floored it to see how much boost I was making I noticed that the gauge hit only 4 psi. Normally the car sees 7 psi on cool days. Was the reduced boost a result of high oil temps, pulling timing or was it because the A/C compressor was engaged or a combination of both? Are these high temps normal?
In another thread I posted how the car felt much less powerful this morning, due to the 85+ degree weather. Normally when I floor the car from a 50+ mph rolling start, the car takes off like a bat out of hell. Today when I did the same thing she felt like she was laboring and very sluggish. It's fairly obvious that FI setups do not like the hot weather and I'm sure that my tuner severely curtailed the timing in the hot weather so that I don't blow my stock bottom end to pieces just yet.......I'm sure that he doesn't want me blaming him for the catastrophe. This will be my first summer with the FI setup so I'm learning as I go along. Looks like the days of 180 degree oil & coolant temps with the tranny at or below that level are history. Thanks for listening to me rant.
Old May 26, 2007 | 07:18 PM
Warp Factor's Avatar
Warp Factor
Lower air density with higher temps hurts power on any motor. It's normal to drop some boost with higher temperatures on a centrifugal, but not almost 50%!
Pulling timing will hurt power, but it won't drop boost on the gauge.
Something else is wrong.
Dirty air filter; leaks; belt slip; blow-off valve not closing?
Old May 27, 2007 | 12:11 AM
Skunkworks's Avatar
Skunkworks
^ What he said. I'd look at other root cause especially very low boost.
Mike
Old May 27, 2007 | 02:11 PM
Laguna Blu's Avatar
Laguna Blu
ttt
Old May 28, 2007 | 12:08 PM
Sportsdude's Avatar
Sportsdude
It was 99 degrees today when I drove and it was running 228 water temperature and 234 oil while in traffic. Water temp went down to 198 and boost was at about 6PSI. I saw about 1PSI of loss.
To Oil temps and boost
