LS2 TB Conversion
Old May 28, 2007 | 02:49 PM
mitymikec's Avatar
mitymikec
Default LS2 TB Conversion
Hey guys I need some help here..My buddy and I are putting a LS2 based motor in his 2003 Z06..He has the 90mm TB and we need to figure our what wires to spice the new harness into..Can anyone help out with this?
Old May 28, 2007 | 07:48 PM
mitymikec's Avatar
mitymikec
ttt...
Old May 28, 2007 | 09:13 PM
EG@EnglandGreen's Avatar
0EG@EnglandGreen
Supporting Tuner
From: ================== Houston, Texas www.englandgreen.com ================== Necessary Evil™ __________
CI 6-7-8-9-10 Veteran
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14
Get the Caspers conversion harness - 108115.
Old May 29, 2007 | 08:15 AM
RoadRebel's Avatar
RoadRebel
PIN ID LS2 90mm
A.) ACT2
B.) ACT1
C.) +5v TPS Reference – Common to both TPS’s
D.) TP1 Signal 0-5v
E.) Common Ground
F.) TP2 Signal 5-0v
98-04 Wiring hookup
A.) ACT 2 - Brown
B.) ACT 1 - Yellow
C.) +5 TPS Dk Green/Wht
D.) TP1 Signal – Dark Blue
E.) TPS GND – Purple
F.) TP2 Signal – Pink
Old May 29, 2007 | 10:24 AM
mitymikec's Avatar
mitymikec
Originally Posted by RoadRebel
PIN ID LS2 90mm
A.) ACT2
B.) ACT1
D.) TP1 Signal 0-5v
E.) Common Ground
F.) TP2 Signal 5-0v
98-04 Wiring hookup
A.) ACT 2 - Brown
B.) ACT 1 - Yellow
Thanks for the info...
Old Jun 4, 2007 | 05:40 PM
C5Sweden's Avatar
C5Sweden
PIN ID LS2 90mm
A.) ACT2
B.) ACT1
D.) TP1 Signal 0-5v
E.) Common Ground
F.) TP2 Signal 5-0v
98-04 Wiring hookup
A.) ACT 2 - Brown
B.) ACT 1 - Yellow
I have a 1999 Corvette C5 LS1, with wiring as stated above (the 98 - 04) for the connection on the throttlebody position feedback connection, however the LS1 throttlebody have a separate connector with + and - to the throttlebody motor, where do I connect those wires to the LS2 90 mm throttlebody??? C and E?
Stupid question but am a bit confused...
Old Jun 5, 2007 | 01:31 PM
NITRO UK's Avatar
NITRO UK
MITYMIKEC HOPE YOUR SORTED
C5 SWEDEN WHAT COLOUR ARE THOSE TWO WIRES??
Old Jun 5, 2007 | 06:26 PM
LB's Avatar
LB
If you are stuck, call me I can pickup a harness from racetronix
Old Jun 5, 2007 | 06:29 PM
mitymikec's Avatar
mitymikec
thanks guys..I got the harness from racetronix..thanks for help..
Old Jun 6, 2007 | 04:46 AM
C5Sweden's Avatar
C5Sweden
Thanx Nitro_UK but I sorted it out!
//Tommy
To LS2 TB Conversion
