I have an A&A car that seems to be using some oil. I am thinking that its in the way I have the PCV setup done. I have a little vacuum going from the intake to the valve cover with a check valve in it to keep from pressurizing the crankcase. Is it possible the vacuum is sucking some of the oil from the valve cover into the intake? Do I need a seperator of some sort in there?
But depending on "How Much" oil is being consumed, it could just be the charicteristics of the motor.
How much oil are you burning?
I just had this very problem!! I just breathed it to atmosphere and all was perfect!! Good Luck!
So you breathe everything to the atmosphere? I am thinking of doing this, I have high-tension rings. It just might get smelly in my catchcan from time to time.
Drive Faster!! The wind blows it right away, that or I'm concentrating so hard on keepint the car under control that I can't even smell it!!! Just kidding, I honestly haven't noticed any extra smell myself, not yet atleast!
