tempature input for tt guys
Old Jun 1, 2007 | 03:12 PM
Carbotech Adam's Avatar
Carbotech Adam
Supporting Vendor
St. Jude Donor '11,'13
Default tempature input for tt guys
what are you pepole seeing with 80+ degres . i have a sts withh a be cool radiator. i see 220-225 degres in that kinda heat. the reason i ask my brother has the same setup but stock radiator and he sees 238-240
Old Jun 1, 2007 | 03:16 PM
jz06man's Avatar
jz06man
I have a 160 theromstat and see temps in the 185-192 range while crusing....
Old Jun 1, 2007 | 09:16 PM
jz06man's Avatar
jz06man
The front of my car is now open with a screen in the front licensee plate cover. This has been good for about 5 degress lower but fast cooling of the oil when i "play" and it gets a little high..
Old Jun 2, 2007 | 04:51 AM
Vince99FRC's Avatar
Vince99FRC
Normal driving in over 90 degree temps in Florida I would avg coolant temps of 190 to 205 degrees depending on stop and go traffic. I have the stock thermostat.
Old Jun 2, 2007 | 11:46 AM
vrybad's Avatar
vrybad
With ambient temps here of 85-95 the last few days, I have coolant temps of 195-198 or so, and oil temps of 200-203, all at cruising speeds on the highway.
They don't change much at all on back roads.
edit: stock t-stat
Old Jun 2, 2007 | 12:39 PM
NigelTufnel's Avatar
NigelTufnel
I have an STS setup too, and with the stock thermo and radiator, I was seeing about 195-205 degrees (fans 1 and 2 were set to come on at 190 and 195 degrees, respectively). With a 160 degree thermo and stock radiator, I see about 175-185 degrees (fans 1 and 2 set at 184 and 194 degrees, respectively). The fan settings come into play during stop and go driving. At highway speeds, they are disabled.
Old Jun 2, 2007 | 07:23 PM
DDSLT5's Avatar
DDSLT5
Even with the 160 stat, when "on it" the oil temps would climb, and the coolant temps would follow. The coolant temps rebound fairly quickly, but the oil just took forever to drop down again - until I had LPE install their oil cooler kit. Now the coolant stays in the mid 170 range and the oil temps are close behind. When hammering it, the oil temps will get over 200 on a hot day (90s) and the coolant temps will climb into the 190 range - once you go back to 'chillin' mode, the coolant drops quickly and within 5 miles the oil temp is back to the low 180s. It might take 40 or 50 miles for the oil temps to drop down the the 190s without the cooler - if it dropped below 200 at all in temps of that nature (90s).
Old Jun 2, 2007 | 10:19 PM
vrybad's Avatar
vrybad
I agree with your results when "on it".
I may need to go with that oil cooler setup.
Thanks for the info.
Old Jun 3, 2007 | 06:36 PM
DDSLT5's Avatar
DDSLT5
I highly recommend it. It allows you to beat on the car as hard as you like and it just never gets hot. The location that the LPE cooler is in is low and behind the radiator instead of in front - so it sheds all its heat down under the engine carriage. This works way better than the stock oil cooler in my ZR-1 which is mounted in front of the rad for reasons that were obviously not too well thought through. I am still running my stock rad in the twin turbo!
Old Jun 3, 2007 | 07:34 PM
vrybad's Avatar
vrybad
Yea, I'll have to put it inline after the turbo oil scavenge pump, but it will be one of my next mods.
I'm still on stock radiator, too, and so far the coolant temps have been very reasonable, but the oil temps do climb.
Thanks again for the feedback, it's nice to hear from people who have it that it works.
Old Jun 3, 2007 | 09:41 PM
PUREFUN's Avatar
PUREFUN
St. Jude Donor '07-'08
Took a 70 mile ride from Vegas to Stateline to pick up some lotto tickets today. Outside temps were 106-110 and my coolant temps stayed at 178 to 185 degrees. Once i got back into the city the temps on the city streets were around 205 degrees. Have a Ron Davis radiator.
To tempature input for tt guys
