From: FI Performance : Norwalk Connecticut www.FIPERFORMANCE.com
APS TT OWNERS best step inside!!!!
So you got an APS TT Kit, good for you!!! Now that you have a great kit, make it even better and dump the Bosch Valves it comes with in favor of a all billet Hyperboost Stealth Diverter Valve... Usually $169 each x2, however, I feel that you guys should be using these instead so to make them even more interesting to you, how about $295 shipped via ground in the lower 48 states!!!
Improve you throttle response now, not later...
I bought a set of these from Brian myself when I first started my kit!!! These pices are great!! while picking them up Brian showed me the difference between the Bosch and these, and it's night and day, I bought them right that minute!! It's money well spent, especially with the guys running more than stock boost!
These don't sound like a dying inbred squirrel like the HKS ones do they??? I'm intent on an upgrade over the bosch valves if I can ever get my car back.
No noise since they are recirc. valves. You may get a slight whoosh, we do on the VAG cars when there is an intake or short ram etc... We have plotted boost curves, bosch 710n vs. the hyperboost and it took a wavey line and flattened it right out. I put these things in anywhere there is a bosch valve, Audi/VW, Porsche, SC BMW's, C5'6's using A&A or ECS kits to name a few... I keep about 30 instock at all times so I will never be out of black.
Tuner's waiting on a new W/B which should be in next week. Car was falling on it's face under boost with the MAF so it's being re-tweaked to a 2Bar SD tune. Hopefully soon, but it's not going to be anywhere near what your setup is (insert bowing guy here).
I can tell you the heat in vegas is KILLING my acceleration!!!
in CA (66-72 degrees)the car with lowest setting 7 psi felt quicker than my fastest setting 12 psi here in vegas 106 outside today and 2500-3000 elevation is not helping. Heat sucks!!!
