Twin Turbo Problems
Old Jun 6, 2007 | 11:52 PM
vegasredz062's Avatar
vegasredz062
St. Jude Donor '08
Default Twin Turbo Problems
Ok the weather dropped to low 80's yesterday and today here in vegas(it was in mid 100's since i got the car)and my nittos 555r are going up in smoke at 80 MPH in 4th low RPM which they NEVER had traction problems even in first gear.With the cooler air the car is unreal.
I have 3 setting 7.5 psi , 9psi, 12psi w/meth.
On the first setting my car blows the tires without any issues 3rd setting is even more stupid
I want to congradulate APS(AND LAPD) on building a monster setup. the car is really and truly an EXOTIC PERFORMING MACHINE!!
Car feels and Drives like it came from the factory until you get on it and the all hell breaks loose.
The Kit delivers
10/10
Old Jun 7, 2007 | 05:58 AM
SpeedyD's Avatar
SpeedyD
The Kit delivers
10/10
Sam, where's the problem????????????????
Congrats Buddy!!!
Old Jun 7, 2007 | 06:49 AM
syko Z06's Avatar
syko Z06
Good to hear your good experiance, i am 1 year from my install of an APS system.
Old Jun 7, 2007 | 12:46 PM
Brabus2's Avatar
Brabus2
Sam, good to hear....have fun with it.
Old Jun 7, 2007 | 01:17 PM
Fastbird's Avatar
Fastbird
Pro Mechanic
C5 of Year Finalist (performance mods) 2019
2017 C5 of the Year Finalist
2016 C5 of the Year Finalist
2015 C5 of the Year Finalist
Jeez, I wish I had YOUR problems.
Old Jun 7, 2007 | 03:35 PM
peter pan's Avatar
peter pan
Life Time NCM #2196
Nice problem to have and what did that 402 TT setup put down
Old Jun 7, 2007 | 03:40 PM
torchvette10's Avatar
torchvette10
Old Jun 7, 2007 | 05:40 PM
vegasredz062
St. Jude Donor '08
PEter,
Here is the dyno#
http://img.auctiva.com/imgdata/3/6/0...51513871_o.jpg
659rwhp and 694 trq. very very safe tune. with new mufflers 3inch pipes it will be over 700 rwhp , im also limited by my fuel setup..
Old Jun 7, 2007 | 07:21 PM
FactoryRaceCar's Avatar
FactoryRaceCar
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12
Old Jun 7, 2007 | 09:11 PM
APS's Avatar
0APS
Former Vendor
The Kit delivers
10/10
Sounds like a nice problem to have, well done to the guys at LAPD and congrats on your twin turbo system install..............what plans do you have for additional traction?
Peter
Old Jun 8, 2007 | 12:50 AM
vegasredz062
St. Jude Donor '08
Peter,
there is no plans for traction , unless you have some idea
Im running the best traction tires for my street setup and that cant even hold the power down..
I am getting used to modulating the power with the gas pedal..80% then all out in each gear seems to work a little better.
there is a great chance i will be at LVS (las vegas speedway tomorrow)
i will have issues as the tires will not hook that well and i DONT want to break anything with a HARD launch.. im really intrested in the MPH ..that will tell the story
I hope traction permitted i can get 135+ in the vegas altitude and DA , IAT wil be up there for sure...
Peter
Old Jun 8, 2007 | 01:18 AM
LB's Avatar
LB
Cooler air = more power. I bet you leaned the car out ...
Canadian cars are fast
Old Jun 8, 2007 | 05:31 AM
SpeedyD's Avatar
SpeedyD
Sam, LB has a point here. If I were you I would really invest in a wideband so you can always monitor your air/fuel, especially since your fuel system isn't upgraded. It only takes one bad run to lean out and kaboom! It's worth the $400! Give me a call if you have any questions, you should still have my number.
Dan
Old Jun 8, 2007 | 10:33 AM
vegasredz062
St. Jude Donor '08
Will 2 cans of torco help ?
and when i go back to LAPD , i might have them install a wideband.
Dan
Old Jun 8, 2007 | 10:42 AM
LB's Avatar
LB
The high octane will help the fuel to burn slower, so it will have less chance of blowing up. Its safe to say that you are beter running rich on a hot day then lean on a cold one.
Old Jun 8, 2007 | 10:58 AM
vegasredz062
St. Jude Donor '08
Ok, So i will load on the torco
My 2 bar tune was set to run "rich" from my tuner. that was something is was "very" strict about.
Old Jun 8, 2007 | 05:25 PM
vetmike01's Avatar
vetmike01
Default I love this problem
Isn't this a fun problem to have?Expect for the price of tires i really enjoy my new found problem that ECS has given me and im sure you are enjoying it to am i right?Mike
Old Jun 12, 2007 | 12:51 AM
APS's Avatar
0APS
Former Vendor
Peter,
There are a number of different brand of boost controllers that allow the tuner to map the boost pressure vs gear ratio..............that's what I would recommend in order to achieve maximum traction in every gear.
Peter
To Twin Turbo Problems
