Did a Leakdown Test and...
Some things to consider:
Engine is ice cold
Pistons could anywhere.
Brand new heads, never run. Do valves really need time to "seat"?
I tested where the crank was at for test 1:
1. 18% 2. 28%
3. 29% 4. 28%
5. 28% 6. 25%
7. 24% 8. 21%
For test 2 I rotated the crank roughly 360* degrees.
1. 24% 2. 30%
3. 32% 4. 32%
5. 25% 6. 20%
7. 24% 8. 40%
From those number I would take a stab and guess that the lower numbers indicate the piston was higher in the bore and the higher numbers mean it was further down. And the number that are same mean the piston was close to same location? The car was put in gear so they wouldn't move.
FYI - A few months back I did a compression test and all the cylinder consistently came in the 170-180 range. Hardly any oil the catch can, maybe a tablespoon. I didn't notice any oil usage over a 3k mile oil run.
I'll do a retest at TDC (when I find it) and see what I get... I hope the numbers get better.
Not good results, but has car been sitting a long time?
That could be your low power problem that you've had for a while.
Your call, but if you have or are close to firing it up, do so and check another day.
Normally wear happens at the top of the cylinder, so even if some pistons were low, they may test better.
I think that you found your low power problem.
40% on number 8? You do mean last hole on passemger's side, yes?
If it was 7, I would say that you are suffering from the broken ring/land disease. Could stillbe the case.
How many miles on engine...are you the orignal owner?
Sorry to hear about your latest findings...keep the faith.
42k on engine. Probably about 23k with the Maggie. I got it with right around 38k.
I'm the second owner. It looked like he took average care of it. But you never know. Like I said before I've analyzed the oil a few times and it's always come back with below average values. Nothing exciting when I pulled the heads or the front cover. Hardly any discoloration - wiped right off. We'll see.
With a compression test, you can turn the engine over until it comes up high, unless it's really bad.
When I do a comp test, I let the engine turn maybe 4 or 5 turns for every cylinder. When you do it again after some miles, do the same thing to get relative results.
I guess I'm closing the barn doors after the horses already got out..
How close are you to firing it up?
Some cheapo Diamond pistons and compstar rods will fix it quick, fast and in a hurry
I just have to go for broke now... I'm not about the replace the bottom end...
FWIW: when I did the compression test I would crank each cylinder for 3 seconds. That was my system. It would go higher if I kept cranking it, but that probably defeats the purpose.
