Need help with P1SC!!
[IMG]
[/IMG]It looks like the older version with the dual intercoolers. The guy I bought the car from, had ordered the hoses, shroud, radiator brackets and filter from Andy @ A&A to change the setup to new style. So I bought the kit from him. Now I am not exactly sure what to do. From what I can tell, I am staying with the dual ic, but moving the air intake from the P1SC over the radiator(?). I can't tell exactly what is in front of the sc intake right now - no room to look and don't want to disasseble yet. Are there any installation threads with pics (search didn't show any)?Can anyone explain what I should be doing here or if I should be doing this at all? I have spent all weekend looking for a clue as to what to do. Any input would be appreciated.
VR
[IMG]
All you do, is remove your radiator, doesn't even have to be all the way outt the car but, it would be easier to remove the fans and radiator.
Then, what you do, is cut the supports, that hold the base of the radiator. You also cut the cross bar, that is mounted to the radiator brackets.
Then, you take that whole assembly, as one unit, and move it forward, 6 inches. Then you either make a bracket to fasten it, or you weld it, like how I did. I am now able to fit all my piping over the shorud area. It fits great, and i'm sure it makes power. YOU WILL HAVE TO MODIFY YOU hose. Which, what I did was have the pipe coming off the water pump, kinda angle down, the come up from the bottom, actually onto the radiator.
If you'd like, email me at jwells@veracadillac.com and i'll shoot you some pictures bro.
Peace out.
J
You might ask him if they have any blower brackets while you are at it.
