I can locate plenty of posts on how well Torco works. Can someone tell me where to purchase at the best price. I just got my car back with a TTi X kit and want to raise her right .
how much should you add to a '02 z06 full gas tank to raise 91 octane to 100 octane?
Since one 32 oz can will bring 10 gallons of 91 up to 96.5, 2 quarts in 18.5 gallons will put you somewhere between 97 and 98 octane.. I've heard of a very reputable tuner getting a little higher octane then I'm quoting, but I like to play it safe...
I've not personally tested exactly how much you'd need to hit 100 with 91 octane, but I put in 2 cans per tank in my car, and run 14#s of boost at 26 degrees of timing with ZERO knock retard!!
JB
So one can go from 91 to 96.5. Using 93 octane as a base and adding one can, do you get the same/similar 5 point lift = 98?
What does 18 gals of 93 with one can equal and the same with two cans??
Joe, thanks for the Torco the 5 gals arrived yesterday. Very quickly!!
Yes, you should be around 98.5, if you start with 93.
With 18 gallons of 93 and 1 can of Torco, you should be around 96 octane. with 2 cans, you should be between 99 and 100 octane!!
