Temp Help
Old Jun 20, 2007 | 10:12 AM
TheBigDog's Avatar
TheBigDog
Default Temp Help
You guys with turbo chargers...What temperature do have tha fans set to come on? Just got a TTi X kit installed and the installer set it at 190* sounds like it runs full time. Should I install a lower temp thermostat.
Thanks,
The Bib Dog
Old Jun 20, 2007 | 01:22 PM
DanTTVette's Avatar
DanTTVette
Stock Thermostat is ~194 so you will need a lower temp thermostat to prevent your fans from running full time.
Congrats on the kit!
Dave
Old Jun 20, 2007 | 04:46 PM
Vince99FRC's Avatar
Vince99FRC
Mine is 190 therm and my fans do kick on at that temp. I dont see the problem..
Old Jun 20, 2007 | 05:20 PM
RoadRebel's Avatar
RoadRebel
uhh you sure about that?
Old Jun 21, 2007 | 11:25 AM
TheBigDog's Avatar
TheBigDog
What temp thermostates are available?
Thanks,
The Big Dog
Old Jun 22, 2007 | 04:28 AM
Sportsdude's Avatar
Sportsdude
Check out 160 degrees
Old Jun 22, 2007 | 04:33 AM
Blown 346's Avatar
Blown 346
I agree with the 160 T Stat, but once that is installed to get the fans to come on at that temp you will have to have the computer tuned for it.
Old Jun 22, 2007 | 05:32 AM
Vince99FRC's Avatar
Vince99FRC
I never changed from the stock therm. I do know the fans kick on around 190 coolant temp.
To Temp Help
