Maggie Hood HELP!
Old Jun 25, 2007 | 01:57 AM
El Calor's Avatar
El Calor
^^That's awesome...thanks for your input! I'm supposed to get the hood delivered tomorrow, so I guess I'll be the test mule
Old Jun 25, 2007 | 09:46 PM
saloonwarrior's Avatar
saloonwarrior
what do you want for your hood?
Old Jun 25, 2007 | 10:31 PM
ABNVET.I's Avatar
ABNVET.I
http://forums.corvetteforum.com/show....php?t=1740428
Old Jun 26, 2007 | 08:08 PM
ABNVET.I's Avatar
ABNVET.I
THANKS for all the replys but I got it to work! Two cuts and it fits. Had my body guy come by and he said not a problem. The hood is CF but it it glued to a fiberglass skin on the under side. EASY fix! I will post some pics when the repair is done and the underside is painted
Old Jul 4, 2007 | 06:28 PM
El Calor's Avatar
El Calor
We need pics
Old Jul 4, 2007 | 10:00 PM
ABNVET.I's Avatar
ABNVET.I
Here is a pic of the cuts. You have to cut the back as you see I angled the edges and I also cut everything from the bottom support down. The hood isnt done yet it will be smoothed and painted blue also. I used a dremel and cut off wheel as you see in the pic to do the cuts. The skin you are cutting is very thin and I didnt see where it was doing anything. It is being held in with dabs of glue. Just take your time score it and make a few passes it took about 30min to do it all.
http://i54.photobucket.com/albums/g9...g?t=1183600487
http://i54.photobucket.com/albums/g9...g?t=1183600735
http://i54.photobucket.com/albums/g9...g?t=1183600757
http://i54.photobucket.com/albums/g9...g?t=1183600794
Old Jul 4, 2007 | 10:43 PM
JR_VET's Avatar
JR_VET
Oh No that won't work becuse it to low in the front part of the Hood. If you remove the cross braces on the hood it still won't fit. But thats a great hood. Been there done that.
Old Jul 4, 2007 | 11:13 PM
ABNVET.I's Avatar
ABNVET.I
It does fit hood shuts fine no problem
