Yeah thats tough on any car. You might look into a BigMouth air scoop. I removed my fog light (Z06 screen area) shrouds completely and it made a significant difference, but I don't have the stock shroud (SC), so it lets more air through the radiator from the front.
Yes, the radiator fans do turn off at speed. Keep in mind, that calibration was done for cars that are OEM and have air dams and properly sealed radiator shrouds. If you are getting too hot at speed and you are not fully sealed around your rad/condensor, you may consider changing those values in the tune and seeing what happens.
Most guys don't realize that the OEM shrouding and air dams ordinarily force air through the condensor and radiator, but when you remove or alter the shroud and a perfect seal is not attained, air will try to go around the radiator instead of through it.
Like sales people, the air will follow the path of least resistance
You could cut holes into the fan shroud to allow more air to pass through the rad while driving. I have pictures of this mod but is having problems posting them.
MIKE
MIKE
I would not recommend this unless you have data to support the notion that it will let the car run cooler/allow more air to pass through the radiator.
It may or may not -- I don't know since I haven't tried it, but I think there's a strong chance that it would suck air through the holes you added instead of sucking air through the radiator, causing low speed coolant temps to rise.
The fans turn off at those speeds because they become a hindrance to airflow, not a help. I wouldn't change it.
You could try going to 100% distilled water + WaterWetter for coolant. That helped my temps a fair amount. Other common steps, like a lower thermostat, won't really help much at speed. If that doesn't get it, time for a bigger radiator.
I have a Ron Davis radiator, 160 thermo.. The issue is that my FMIC sits in front of my radiator restricting flow.. As long as I am rolling on the freeway I am good... its in stop and go that the temps go up... I figured the fans may be a good idea...
