Is anyone out there running a BOV on the Vortech S-Trim kit? If so how did you do it?
I'm running an HKS BOV SSQ. All you need to do is weld on a flange after the supercharger outlet either before the intercooler or after it and attach the BOV to the flange with a supplied c-clip. Hook up your vaccum line and thats it. Rev and enjoy. Also, you can go on e-bay and look for aluminum piping with the flange already welded on in a variety of sized piping.
In Andy's kit the MAF is relocated near the throtle body making it a push through system. I have the Vortech kit from Vortech the system is a draw through.
Draw through setups are bad. The BOV will release METERED air when it opens. The car still thinks there is all the air it read from the MAF so it will add the corresponding fuel. The car will be extremely rich when the car goes from boost to no boost. Running a car rich will wash down the cylinder walls with fuel, removing the thin layer of oil, and will cause the rings to wear out prematurely.
From: AKA Harvey Mushman-I know just enough to be dangerous "Those who sacrifice liberty for safety deserve neither"- B. Franklin
Senior Member
Cruise-In V Veteran
You always want the BOV before the MAF.
Keith
I don't disagree. I also have the Vortech kit and was wondering if it can be modified.
