Old Jul 8, 2007 | 07:45 PM
Laguna Blu's Avatar
Laguna Blu
Default 246/221/237
No it's not a new custom cam grind but rather the oil temp, coolant temp & tranny temp, in that order, that I observed while driving on the highway at approx 60 mph today in the 90+ degree heat with the A/C blasting. It's fairly obvious that FI applications do not like the heat. I already have a Dewitts radiator and a tranny cooler ( a small one but a cooler nonetheless). Prior to being FI my tranny temps rarely, if ever, exceeded 200 degrees and usually hung around 180 or so with the oil temps usually at 210 or below and coolant at or just below the 200 mark in similar heat. I also noticed less boost than usual under hard acceleration but I was told that it is normal the way my car is setup.
Old Jul 9, 2007 | 09:26 AM
kromberg's Avatar
kromberg
You should get a bigger tranny cooler. 237 degrees has already caused damage to the clutch packs. Not a lot, but it has still started to weaken them.
Keith
Old Jul 9, 2007 | 11:48 AM
Laguna Blu's Avatar
Laguna Blu
Keith
Gee that's good news The unit has already been upgraded and re-built by The Vette Doctors. I certainly do not want to fry this unit.
Old Jul 9, 2007 | 06:35 PM
Zrod's Avatar
Zrod
Try Halltech's nose piece for some more direct hit air, try engine oil cooler, try custom shrouding to force air through radiator, condenser, and FMIC if you're setup that way.
Recently was having high oil temp issues, these measures really helped the high temp issues.
coolant now 178-190 plus or minus
oil temps now 194-210
Old Jul 9, 2007 | 09:18 PM
frank dupuy's Avatar
frank dupuy
At 60 mph on the highway your coolant should be like 210%. You might want to check the front
Old Jul 11, 2007 | 12:49 PM
RBCZ06's Avatar
RBCZ06
Hey Spence it's really a shame that this issue isn't addressed by the FI manufacturers as this seems to be an inherrent problem with blowers. It is the main reason holding me back from going that route. To go from 185 degree tranny temps to 240 just by strapping on a blower is crazy.
To 246/221/237
