X/H pipe
Old Jul 10, 2007 | 11:22 AM
FRCTony's Avatar
FRCTony
Default X/H pipe
Does anyone know what is available to replace the stock H pipe with out cutting?
It seems Bassani makes what I'm looking for but I can't quite figure out the part numbers required.
Any other manufacturers?
Must fit 99FRC with stock manifolds.
Thanks!
Old Jul 12, 2007 | 03:57 PM
Blue Angel's Avatar
Blue Angel
Stock H pipe is welded to the cats... if you don't want to cut anything you'll need to replace the whole thing. I don't think anyone makes a replacement setup with cats that bolts to the stock manifolds...
You'll have many options if you cut behind the cats.
Old Jul 12, 2007 | 09:29 PM
FRCTony's Avatar
FRCTony
Actually, catless is what I'm after, I just don't want to cut the stock h pipe.
Old Jul 13, 2007 | 06:19 AM
Blue Angel's Avatar
Blue Angel
I think your only option would be to buy an aftermarket X pipe and have an exhaust shop fab up something to connect it to the OEM manifolds... they should have flanges and hardware to mate up to the three bolt manifolds I would think.
Old Jul 13, 2007 | 08:57 AM
JoeyG's Avatar
JoeyG
Cruise-In III Veteran
Cruise-In IV Veteran
I'll make you a deal on a Corsa X-pipe so you can add off road pipes also
To X/H pipe
