alky pump
Old Jul 11, 2007 | 03:26 PM
wrustywrench's Avatar
wrustywrench
Default alky pump
I mounted my alky pump with the pump on top,, mostly due to the lenght of line I was given....
i can see that the pump down would be prefered if any leakage got into electric motor,, but other than that, is there any advantages..
should I turn it over or leave it along, I have had no problems
Old Jul 11, 2007 | 03:49 PM
SpeedyD's Avatar
SpeedyD
See below for the correct answer!!!
Old Jul 11, 2007 | 03:53 PM
SteveDoten's Avatar
SteveDoten
Cruise-In VII Veteran
if your supply line is braided s/s, you have the older kit, the earlier lines were slightly shorter
the past 6 I've seen use the longer supply lines
Old Jul 11, 2007 | 04:38 PM
DOUG @ ECS's Avatar
DOUG @ ECS
Premium Supporting Vendor
From: Providing the most proven supercharger kits for your C5/6/7 609-752-0321
We decided to flip it upside down just in case of a leaking situation, that way the pump does not get corroded. Mine is positioned the original way and I have no intentions of changing it.
We had a few guys over tighten the fitting into the pump and crack the housing, it ended up ruining the pump also. We warrantied the few that did that without a hesitation, but when absorbing someone else's mistake we figured it would lesson our blow if we just mounted the pumps like that from then on. It would of been much cheaper to just replace the cap, which is what we would be able to do now.
Old Jul 11, 2007 | 09:03 PM
wrustywrench
WOW, great replys from some real good guys,,,,,,great vendors too.
I will leave it alone, it is the earlier set up, but it has been upgraded ,, but I still got the short hose,,lol
( opened my self up for any comments,,,lol)
thanks, for the replies
Old Jul 12, 2007 | 12:27 AM
Jeff @ TPE's Avatar
0Jeff @ TPE
Former Vendor
St. Jude Donor '06 & '12
Hey Doug,
If I have a pump with the date of 2/06 on it, is it the updated version or the original version?
Old Jul 12, 2007 | 05:51 AM
SpeedyD's Avatar
SpeedyD
Originally Posted by AMERICAN_HP
Hey Doug,
Jeff, if both line for the pump, in and out are stainless, it's the old version, the new version has a black mesh coated line for the inlet. It's a little bit longer
Dan
Old Jul 12, 2007 | 06:35 AM
wrustywrench
let me add, the guys at ECS and Julio are the best when it comes to service. Julio e-mailed and called on a sunday,,,,now that is service.
Even upgraded the pump for free.......
To alky pump
