Clutch problem
Old Jul 16, 2007 | 12:22 AM
furio666's Avatar
furio666
Default Clutch problem
I just got my A and A vortec installed and I think my clutch might not be good when I drive the car normal the clutch is fine when i get on it I am losing pedal pressure the pedal gets lower to the floor is the clutch gone or is the fluid gone bad
Old Jul 16, 2007 | 12:56 AM
Scubanme's Avatar
Scubanme
Very common problem on C-5s. I just had my cluth changed because of the same reason.
Old Jul 16, 2007 | 01:03 AM
furio666's Avatar
furio666
Did it help the problem
Old Jul 16, 2007 | 11:46 AM
HP_Addict's Avatar
HP_Addict
changing the clutch will fix the problem. Check out the Tex OZ700.
Old Jul 16, 2007 | 11:52 AM
Jeff @ TPE's Avatar
0Jeff @ TPE
Former Vendor
St. Jude Donor '06 & '12
When you get on it, is the clutch slipping? Or is it just the pedal travel? If its just the pedal, then it sounds like a hydraulic issue.
How is the engage/dis-engage on the clutch?
Old Jul 16, 2007 | 11:59 AM
AVB's Avatar
AVB
Since the car is driveable...kinda, when was the last time clutch fluids were bled or freshened up? If the fluid is black or it's been a while, get the old fluid out (at the top if you don't have a remote bleeder) and get good fluid in there. Do that a few times after driving and eventually it'll stay clean.
Arnel
Old Jul 17, 2007 | 01:06 AM
YeloZ06's Avatar
YeloZ06
I dropped my 02 Z06 off today for the same problem? When I get on it and go to shift the pedal stays down. I have to lift the pedal up with my foot. No slipage. I think its a hydraulic issue (slave cylinder)? I had no leeks in the line. I'm changing the fluid and while I'm at it also changing brake and rear diff fluids as well. Good luck!
Old Jul 17, 2007 | 05:44 AM
EPP's Avatar
0EPP
Former Vendor
We have had cases like this where changing out the fluid helps out, but more than likely it is either a master cylinder or slave cylinder problem. What to do? Start with the easy choices first and see if it helps. Bob
Old Jul 17, 2007 | 10:15 AM
YeloZ06's Avatar
YeloZ06
Old Jul 17, 2007 | 10:25 AM
SteveDoten's Avatar
SteveDoten
Cruise-In VII Veteran
We offer a one stop solution:
1. Textralia OZ700 clutch kit(SB flywheel, disc, pressure plate)
2. GM slave cylinder(latest updated version)
3. GM pilot bearing
4. GM flywheel bolts
5. Charlie/RPM Motors remote bleeder
$1249 shipped, lower 48
We currently have a few unspoken for in stock
To Clutch problem
