Fast intake and FI?
There have been a few post about the FAST intakes and FI.Get yourself an LS2 intake set-up with a hand port job, I've been told that this really improves performance of FI motors.
Units that break ..may be due to other install issues
Tom
*edit added after post was created: FWIW I searched LS1Tech and was able to find one thread where someone exploded a FAST on startup of his new motor -- claims a big backfire was to blaim. Burst panel was not installed.
I'm not doubting that a few intakes have popped, but I am wondering what the occurrence rate of this is, and what it is due to. I have heard of FAST intakes cracking when the valley hardware is not replaced with the hardware from FAST, as the OEM bolts are too tall for the intake.
Looking at the construction of the intake it's hard to see how 15-18psi of boost could destructively blow it up and take out the fuel rails. Backfire could definitely take it out, but as you mentioned that burst panel would save it.
Again, not doubting that it has happened but I've also seen LS6 intakes go kaboom due to backfire. The pressure of a backfire event is so tremendous that *something* is going to give *somewhere*. The intake is likely the least expensive of the parts that could break (which wouldn't happen with the burst panel anyway).
If anyone has any additional info please link/post here. On the other thread that got started on the FAST burst issue I wasn't able to find any concrete information or links to concrete information.
I am guilty of this too, so I am not meaning to sound condescending, but sometimes one or two isolated incidents pick up steam and everyone starts talking about them like they are a chronic issue. If the FAST thing really is a chronic issue I want to know now
