tooshort
Jul 22, 2007 | 06:27 PM
tooshort
Heatting problems big time.tried just about every thing,new dewett rad car is equip with 408ci with f1c sc,need help.
Jul 22, 2007 | 06:41 PM
What thermo are you running?
Do you have FMIC?
Some solutions are Spal fans, Water wetter, 160 thermo, and/ or evans water pump...
Jul 22, 2007 | 06:50 PM
tooshort
have 160, and stock fans
Jul 22, 2007 | 06:52 PM
tooshort
O ya I have water wetter with distiled water.
Jul 22, 2007 | 07:33 PM
Some more details about your setup would be helpful.
Do you have an air dam?
Is there shrouding covering the top of your radiator/condensor?
Jul 23, 2007 | 11:15 PM
tooshort
yes I do,I have the ati kit on it,with the metel shord.
Jul 23, 2007 | 11:30 PM
So it's the ATI kit with the ATI supplied fan shroud (single fan?) If so, ditch it. That thing sucks at cooling and it kills your IATs.
Jul 24, 2007 | 08:53 AM
St. Jude Donor '05-'06-'08
Quote:
Originally Posted by
tooshort
Time to change the stock fans, also have you had it tuned yet.......Did the tuner set it right!
Jul 24, 2007 | 10:46 PM
tooshort
No,it is the stage2 kit.And yes it was tune right by hpe.
Jul 24, 2007 | 11:11 PM
Is it water temps and oil temps or just water. Blown head gasket? Sx cool running around town heat up quick with power vs cool at speed heats up quick around town. I have a 427ci with a procharger and water temps 180-200 even when its 90+ outside.
Evans wtr pumps are the way to go to get flow at speed. Right now i like the Elect wtr pump because i do a lot of stop and go driving. It gives full flow all the time, but may fall short at WOT 6000+rpm. Giva and take
