Two alky systems????
Old Jul 28, 2007 | 12:35 AM
LV Vette's Avatar
LV Vette
St. Jude Donor '08
Default Two alky systems????
I am thinking of increasing my boost at lower rpms (another post) and also using my alky injection as a power adder and not just as “insurance” as I am now. Problem is I have this fear of the alky failing and the motor going kaboom. So I was wondering if anyone has ever installed two complete separate alky systems in case one fails?
Thanks,
Clayton from Las Vegas
Old Jul 28, 2007 | 01:07 AM
Skunkworks's Avatar
Skunkworks
Thanks,
A closed loop system can offer sufficient results, but a fail safe mechanism must be employed.
Mike
Old Jul 28, 2007 | 01:25 AM
LV Vette's Avatar
LV Vette
St. Jude Donor '08
Mike
Which is what? I have no idea how to accomplish this.
Calyton from Las Vegas
Old Jul 28, 2007 | 08:38 AM
Gannet's Avatar
Gannet
St. Jude Donor '06
How is alky going to be a power adder?
Old Jul 28, 2007 | 10:08 AM
Tony @ MPH's Avatar
Tony @ MPH
Supporting Vendor
Alky is a power adder when you retune for it and add timing.
Old Jul 28, 2007 | 10:49 AM
eb02z06's Avatar
eb02z06
St. Jude Donor '08
Put your alky nozzle before a IAT sensor-tune the car with alky to a safe 10.8 on the road-if the alky fails your AFR will rise to 11.8-still safe-program the computer IAT tables to pull timing down to 10 degrees if IAT temps go above 130 degrees.
Old Jul 28, 2007 | 11:57 AM
FreddyG's Avatar
FreddyG
This is good info...Thanks Arun! What if the IAT sensor is built into the MAF (2001 5 wire MAF)? Should I move the IAT sensor and where is the best place to put it?
Thanks again for the info Arun and LV Vette for the thread!
Old Jul 28, 2007 | 12:07 PM
jbsblownc5's Avatar
jbsblownc5
2017 C5 of the Year Finalist
St. Jude Donor '08
I've run Alky for a few years now. I relocated my IAT after the nozzle. I also run Torco, so my octane is up there anyway. There is also a light on alkycontols system that tells you when you are making pressure.
Works for me.
JB
Old Jul 28, 2007 | 12:54 PM
Gannet's Avatar
Gannet
St. Jude Donor '06
That doesn't make it a "power adder". It's the change in tune that adds the power. All the alky does is keep it from blowing up. If alky is a power adder, a bigger radiator is a power adder, race gas is a power adder, etc.
Old Jul 28, 2007 | 01:05 PM
Tony @ MPH's Avatar
Tony @ MPH
Supporting Vendor
Turbos are a power adder in your definition, correct?
How much power do you think they add at 15psi without a retune?
We're splitting hairs to argue this point at all, and no -- alky is not officially considered a power adder -- but I thought your question was a genuine one about how alky adds power, not a question intended to point out that not all things that add power are considered power adders.
Old Jul 28, 2007 | 01:32 PM
FreddyG's Avatar
FreddyG
Works for me.
JB
Thanks JB!
Alky is a power adder because it's what allows you to add more timing or another pound or two of boost. It's the means to an end. It keeps it cooler so that it doesn't blow up, kind of like a wet N20 system adds fuel to keep the spray from scattering engine parts on the road.
If you don't think meth is a power adder, then why don't the Guys who race the Top Fuelers run gasoline? It's because the NitroMETHane supports the extra burn, or look at a Top Alcohol funny car or an F1 car.
I'm not trying to start an arguement or anything, just giving my point of view and offering fuel (pun intended) for a FRIENDLY debate.
Old Jul 28, 2007 | 02:03 PM
eb02z06's Avatar
eb02z06
St. Jude Donor '08
You can get an IAT sensor relocation kit from Caspers or Jet-just cut the 2 wires going to the maf and join them to the iat sensor relocation kit.
This will also give you better perfomance on hot days as the iat sensor will see the actual temperature with meth spraying so it can account for it.
Old Jul 28, 2007 | 04:27 PM
FreddyG's Avatar
FreddyG
Thank You!
Old Jul 28, 2007 | 05:18 PM
Paul Cheung's Avatar
Paul Cheung
Default safeinjection
Hi
I have safeinjection by snow it senses if there is meth flowing and if there is a failer that it will open your blowoff valve so you cant make boost .It is a great failsafe devise.............
Thanks Paul.............
Old Jul 28, 2007 | 07:00 PM
MIKE-C5's Avatar
MIKE-C5
St. Jude Donor '05-'06-'08
Mike
To Two alky systems????
