D1SC boost question
Old Jul 28, 2007 | 04:45 PM
WeaponsGradeTorque's Avatar
WeaponsGradeTorque
Default D1SC boost question
How effecient is the D1SC head unit in a low boost application. For example, 5.0 PSI on a 427??
In this case, the head unit might be spinning only 43,000 to 45,000 RPMs.
Old Jul 28, 2007 | 05:28 PM
eb02z06's Avatar
eb02z06
St. Jude Donor '08
The D1 is a very effecient unit right up to redline-it will be hard to put a number on boost until you have it on your car-so many factors like cam, heads come into play.
Old Jul 28, 2007 | 06:49 PM
WeaponsGradeTorque
Good. Right now I have a P1SC. I want to switch over to the D1SC (because i can get a good deal on one). I plan on running 5.0 - 6.0 PSI and want to make sure I won't lose any power.
Old Jul 29, 2007 | 04:22 PM
MIKE-C5's Avatar
MIKE-C5
St. Jude Donor '05-'06-'08
The D1SC is a great Blower! !
Old Jul 29, 2007 | 05:21 PM
WeaponsGradeTorque
Not disagreeing. My question is about efficiency of the D1SC at low pressure ratios. If Procharger published compressor maps, I wouldn't have to ask this question on a forum.
Old Jul 29, 2007 | 06:32 PM
Tony @ MPH's Avatar
Tony @ MPH
Supporting Vendor
Interested in what kind of efficiency you see in practice at that level vs. a P1SC.
I noticed the Procharger C6 Z06 kits use a P1SC-1, most of them only going to 6psi. So I am wondering if it is expense or other reasons driving them to put a P1SC instead of a D1SC on a 427.
Old Jul 29, 2007 | 06:55 PM
Skunkworks's Avatar
Skunkworks
Theoretically you get better low RPM (engine) response because you are spinning it faster. It starts to flow better faster, but it's outside it's good efficiency island thus producing more heat and parasitic drag.
Mike
WeaponsGradeTorque
I've been pretty impressed with the P1SC-1. I believe, but not 100% certain, that there is a nose off in power after 6400 rpm because the P1SC runs out of efficiency. This is with 5.0 psi and 650 rwhp. I don't think the drop off at 6400 rpm is a huge issue, and it is more pronounced with the more power being made. With the stock setup and 600 rwhp, I think the noseover is very small and Procharger probably saw more area under the curve with the P1SC-1 with the stock setup. But I have headers and a cam that is pushing me up. The D1SC "might" be better in my case for higher RPM power. Maybe not. This is all a big mystery to me as well.
Old Jul 29, 2007 | 06:58 PM
WeaponsGradeTorque
Mike
You don't know how bad I want to see the efficiency islands for the D1SC. Are you agreeing that the D1SC might not be efficient at lower boost pressure ratios? (i.e. boost 5-6 on an LS7?) Love to hear your opinion on this.
Old Jul 29, 2007 | 09:22 PM
Skunkworks's Avatar
Skunkworks
I would think your better off with D1SC... you'll be operating at better efficiency then P1SC.
Most look at max RPM of blower but when you look at say vortech's maps you can see that max RPM efficiency is not that great.
The D1SC will be operating closer to efficiency sweet spot but definitely not in it. Poor efficiency adds up in both heat and parasitic loading, or you have to shed more heat and your pulling more power from crank.
As far as LS7 kit from Procharger with P1SC, I'd suspect they want upgrade $$$ to D1SC or they get you later with upgrade (win, win). Or it can be self governing in terms of it can't put out much past that.
I think D1SC will get you better results then P1SC even at your boost numbers. There is a considerable difference between stock cube LS1/6 and LS7 in terms of mass flow demand (at least 25%). Just look at when people run out of blower on LS1/6 with P1SC... Also P1SC is probably done at about 900 CFM speaking from a efficiency standpoint.
Without compressor maps it's just speculation on both our parts...
Mike
EDIT --- Got same color C6 but not Z06. Can you get a good deal on F1A?
Old Jul 29, 2007 | 10:46 PM
Tony @ MPH's Avatar
Tony @ MPH
Supporting Vendor
I think you are right on this one Mike.
WRT running a D1SC on lower boost apps, if you are out of an ideal location on the island with that head unit and low boost -- a restrictor might be appropriate. The smaller pulley size/restrictor combo would push you closor to where you want to be at lower RPMs while keeping you from going off the deep end at upper RPMs.
Amazing how something so simple as a restrictor plate -- which was largely unbeknownst to the C5 FI community only 1.5 to 2 years ago -- bears so much utility when it comes to C5 FI today.
Old Jul 29, 2007 | 11:53 PM
Skunkworks's Avatar
Skunkworks
Oddly I ran a parametric study on this (me being the dork I am). Using an ideal compressor curve (centrifugal) you do come up on a point point of diminishing returns. Ran numerous scenarios and in few cases restrictor was detrimental, oddly at lower PRM (motor).
Not trying to hijack a thread, so I'm out.
Mike
Old Jul 30, 2007 | 07:57 AM
WeaponsGradeTorque
Mike
Mike,
Thanks for the input. All of your points certainly make sense. At the time of purchase, upgrading was only like $200
I am going to move forward with this experiment. I'll keep you guys posted. Maybe I should think about the F1 instead of the D1 while I am at it!!
p.s. And Lemans Blue is a great color!
Old Jul 30, 2007 | 09:10 AM
Tony @ MPH's Avatar
Tony @ MPH
Supporting Vendor
Would be interested in seeing the parametric study -- if restrictors kill efficiency more at low end instead of high end that would go against everything we know about restrictors in practice and why they are used. Not saying it doesn't happen on paper, but it just seems there are so many examples of dropping pulley size, adding restrictor, gaining low end, and softening top end. If the OP feels this is a hijack I apologize, I thought it was relevant to the question at hand.
WeaponsGradeTorque, regarding the nose dive at 6400RPM -- that may be belt slip, or like you said, it could just be the limits of the blower. I don't recall seeing any 700rwhp dyno graphs from a P series so I am leaning towards efficiency.
Old Jul 30, 2007 | 03:13 PM
Skunkworks's Avatar
Skunkworks
I noticed a low to mid range dip once restrictor got very aggressive... When restrictor was reasonable there was no dip or excessive losses. If you go crazy the disk will exhibit losses at very low RPM say 1000 engine RPM.
Remember you have two exponential curves (restrictor and supercharger). The part that is hard to factor in on paper is how the compressor reacts at low RPM when it just starts to flow well. The restrictor allows you to push more RPM (blower) thus getting it to flow better faster.
If you want I can dig up my old calculations.
Mike
Old Jul 30, 2007 | 03:15 PM
Skunkworks's Avatar
Skunkworks
Mike,
Not sure on the F1A, that might be too much at your target range.
Mike
Old Jul 30, 2007 | 08:05 PM
WeaponsGradeTorque
Mike
D1SC ordered today. I'll let you guys know how it goes.
Old Jul 30, 2007 | 08:41 PM
vetterlatethannever's Avatar
vetterlatethannever
To D1SC boost question
