**help! My Car Blew Up**
I wont be able to diagnose it until later this week...but any ideas guys please.
Dustin
Dustin
it doesn't matter what happened to it Now you have a chance to build the hell out of it ...get you a forged block and make some real power
congratulations
And the funny thing is that I was watching the temps and the coolant maybe got to 200 if that, the oil was prob 217 or so and everything was in order, I didnt even hear pinging.....this sucks.
Dustin
Dustin
347 LS6 forged pistons & rods (stock crank) $2,789 no core $0 SDPC (TX) Post $2,789
347 LS6 forged pistons (stock rods & crank) $2,095 plus core $800 Lingenfelter (IN) $2,895
_____$3,000+_____
370 Iron forged pistons & rods (stock crank) $3,299 no core $0 MTI (TX) $3,299
347 LS6 Stg1 forged pistons (stock rods & crank) $2,395 plus core $1,000 Rapid Motorsports (PA) $3,395
347 LS6 forged pistons & rods (stock crank) $2,595 plus core $1,000 FLP (IL) $3,595
402 Iron forged pistons, rods, crank $3,599 no core $0 Rapid Motorsports (PA) $3,599
347 LS6 forged pistons & rods (stock crank) $2,600 plus core $1,000 (est core) HPE (TX) $3,600
347 LS6 forged pistons & rods (stock crank) $2,700 plus core $950 Cartek (NJ) $3,650
347 LS6 forged pistons & rods (stock crank) $2,799 plus core $1,000 (est core) Speed Inc (IL) $3,799
402 LS2 forged pistons, rods, crank $3,800 no core $0 Texas Speed(TX) Special $3,800
402 LS2 forged pistons, rods, crank $3,900 no core $0 Tbyrne Motorsports (MA) $3,900
347 LS6 Stg1 forged pistons & rods (stock crank) $2,995 plus core $1,000 A&A Corvette (CA) $3,995
347 LS6 forged pistons & rods (stock crank) $2,995 plus core $1,000 MTI (TX) $3,995
347 LS6 forged pistons (stock rods and crank) $3,000 plus core $1,000 (est core) ARE (CAN) $3,995
347 LS6 Stg2 forged pistons (stock rods & crank) $2,999 plus core $1,000 Rapid Motorsports (PA) $3,999
402 LS2 forged pistons, rods, crank $3,999 no core $0 Rapid Motorsports (PA) $3,999
_____$4,000+_____
347 LS6 forged pistons & rods (stock crank) $3,095 plus core $1,000 Thunder Racing (LA) $4,095
402 LS2 forged pistons, rods, crank $4,095 no core $0 SDPC (TX) Special $4,095
347 LS6 S2 forged pistons & rods (stock crank) $3,595 plus core $1,000 A&A Corvette (CA) $4,595
403 LS2 forged pistons, rods, crank $4,595 no core $0 Lingenfelter (IN) $4,595
383 LS6 forged pistons, rods, crank $3,995 plus core $650 Thunder Racing (LA) $4,645
382 LS6 forged pistons, rods, crank $4,395 plus core $600 FLP (IL) $4,995
370 Iron forged pistons, rods, crank $4,900 no core $0 ARE (CAN) $4,900
_____$5,000+_____
408 Iron forged pistons, rods, crank $5,000 no core $0 Cartek (NJ) $5,000
382 LS6 forged pistons, rods, crank $4,500 plus core $600 Cartek (NJ) $5,100
402 LS2 forged pistons, rods, crank $5,395 no core $0 Rapid Motorsports (PA) $5,395
408 Iron forged pistons, rods, crank $4,600 plus core $1,000 (est core) Speed Inc (IL) $5,600
408 Iron forged pistons, rods, crank $5,995 no core $0 Rapid Motorsports (PA) $5,995
402 LS6 forged pistons, rods, crank $5,995 no core $0 Rapid Motorsports (PA) $5,995
_____$6,000+_____
408 Iron forged pistons & rods (stock crank) $6,295 no core $0 MTI (TX) $6,295
408 Iron forged pistons, rods, crank $6,296 no core $0 FLP (IL) $6,296
383 LS6 forged pistons, rods, crank $5,395 plus core $1,000 (est core) Rapid Motorsports (PA) $6,395
383 LS6 forged pistons, rods, crank $5,795 plus core $800 Lingenfelter (IN) $6,595
388 LS6 forged pistons, rods, crank $5,700 plus core $1,000 (est core) ARE (CAN) $6,700
383 LS6 forged pistons, rods, crank $5,795 plus core $1,000 A&A Corvette (CA) $6,795
412 LS2 forged pistons, rods, crank $6,995 no core $0 Rapid Motorsports (PA) $6,995
_____$7,000+_____
396 LS6 forged pistons, rods, crank $6,000 plus core $1,000 (est core) ARE (CAN) $7,000
408 LS6 forged pistons, rods, crank $6,995 plus core $1,000 A&A Corvette (CA) $7,995
427 LS6 forged pistons, rods, crank $7,995 no core $0 Rapid Motorsports (PA) $7,995
_____$8,000+_____
427 LS6 forged pistons, rods, crank $7,500 plus core $600 Cartek (NJ) $8,100
409 Iron forged pistons, rods, crank $7,900 plus core $400 (est core) ARE (CAN) $8,300
427 Iron forged pistons, rods, crank $8,350 no core $0 ARE (CAN) $8,350
385 LS6 forged pistons, rods, crank $7,550 plus core $1,000 (est core) ARE (CAN) $8,550
396 LS6 forged pistons, rods, crank $7,850 plus core $1,000 (est core) ARE (CAN) $8,850
427 LS6 forged pistons, rods, crank $7,500 plus core $1,000 (est core) Speed Inc (IL) $8,500
_____$9.000+_____
427 LS6 forged pistons, rods, crank $9,000 plus core $1,000 (est core) ARE (CAN) $10,000
441 LS6 forged pistons, rods, crank $9,300 plus core $1,000 (est core) ARE (CAN) $10,300
427 C5R forged pistons, rods, crank $11,995 no core $0 FLP (IL) $11,995
427 LS6 forged pistons, rods, crank $12,639 no core $0 Lingenfelter (IN) $12,639
Let me know how far off I am on this guess.
Pull your plugs and see if any are wet, and then do a compression check. Check to see if you have water in youru oil too. Sorry to hear about your motor. Hope you get it back running soon.
The white smoke can be deceiving to...if oil sprayed out (like from a popped up dipstick)...it can burn on the header and make lots of white/blue smoke too. It's only really blue/grey when its getting mixed with fuel and sent out through the exhaust valves and cats.
The good news is that maybe it didn't scar up the walls of your cylinders too bad and all you will need is some forged pistons (3.905") over bore and new rods to rebuild.
I have put over 800 rwhp and torque using the stock crank...so don't waste your money on a crank unless you want to go to a 4-4.125" stroke.
I know this is all possible because... all that happened to me years ago.
I did go overboard on the supercharger rebuild... and only did so because I upgraded my supercharger system when I had my new engine built.
Dustin
Dustin
