From: Punta Gorda FL A Man's got to know his limitations!
Instructions/Help installing KB Boost a Pump.
Looking for instructions for installing a KB Boost a pump. Any pics would be helpful. Want to tap into the wiring harness. I believe it's behind the drivers side rear quarter panel. Thanks in advance.
TT is up and running. Only problem is a voltage output problem with the new alternator. Only putting out 11 volts and pulling my new Optima red top down. Also getting a 1637 code. Here's some pics.
Thanks moparnos. I'm not using the racetronix harness so I need to know how it is direct wired into the system. I know a lot of people have installed these so if you have any pictures or instructions please let me know. Thanks.
People who do not use our harness usually mount the BAP in the battery box and tie into the fuel pump wiring in the electrical center. if you hardwire the BAP it will be much harder to diagnose problems plus you just compound the voltage loss in the factory wiring.
How much would the harness be to hook the BAP into the fuel Pump wiring. I need to get it installed temp. for my dyno this Saturday. If anyone knows how to hardwire it inline please respond. If I can get the kit next week by Wed. I can install it in place of the temp. wiring.
Originally Posted by Racetronix
Thunder Racing or LPE should have them in stock.
Would you have any knowledge of what wires in the stock harness I can connect to and temporarily get the pump functioning. I'll need it to be working for my Dyno tune Saturday. The TT's are gonna need the extra fuel supply.
Perhaps LPE can provide you with this info as they used to install them into the battery box before they started using our harnesses.
There should be a wire inside the electrical center inside the battery box because that is where the fuel pump relay and fuse are.
Trying to locate which wires in the electrical box next to the battery I need to tap into for the KB BAP. Anyone know or have any pics? The Information online was sketchy at best.
Surely someone has installed a KB BAP by tapping into the factory fuel pump wiring near the battery. any pics and instruction would be greatly appreciated.
