flex plate carnage !!!!
Old Aug 14, 2007 | 11:05 AM
roythomas's Avatar
roythomas
Default flex plate carnage !!!!
many may no my zo6 was converted to a4..my vette had slight vibration brought it to the shop ..and the flex plate was tore all the way around !!! that piece common threw the vette would make a mess of vette and legs perhaps...any one consider making this piece stronger ????
Old Aug 14, 2007 | 12:54 PM
eb02z06's Avatar
eb02z06
St. Jude Donor '08
I think TCI has an SFI approved one Roy. When I got my swap done i asked Rodney and he said he never seen one go so we didn't pursue it any further-I'll see if I can find the link for the TCI.
Old Aug 14, 2007 | 12:56 PM
eb02z06's Avatar
eb02z06
St. Jude Donor '08
Here you go bro:
http://www.compperformancegroupstore...ct_Code=399753
Old Aug 14, 2007 | 01:30 PM
roythomas's Avatar
roythomas
thanks bro !!! that was close call !!! it was a mess and i barely felt the vibration
Old Aug 14, 2007 | 01:36 PM
roythomas's Avatar
roythomas
should have put this up yesterday .. mr bob hilton hooked me up !!! i'm putin this in next round !!!!
Old Aug 14, 2007 | 01:37 PM
RoadRebel's Avatar
RoadRebel
Last I check those do not work for the C5. No place to bolt the splined retainer for the torque tube.
Old Aug 14, 2007 | 02:12 PM
Andre's Avatar
Andre
(scroll to bottom of page)
http://www.streetperformance.com/pre...asearchive.php
Company: JW Performance Transmissions
Title: New Precision Machined, High Strength Steel Flywheel-Flexplate For GM LS1 V-8 Engine Family
Document: Click Here
Picture: Click Here
Old Aug 14, 2007 | 02:35 PM
eb02z06's Avatar
eb02z06
St. Jude Donor '08
I wasn't 100% sure but thanks for letting us know Phil-wasn't Doug at ECS also working on some hardened parts for the A4 setups?
Old Aug 14, 2007 | 02:56 PM
EG@EnglandGreen's Avatar
0EG@EnglandGreen
Supporting Tuner
From: ================== Houston, Texas www.englandgreen.com ================== Necessary Evil™ __________
CI 6-7-8-9-10 Veteran
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14
Correct - it does not work.
There are no alternatives to stock.
<edit> The reason I am so confident is I bought a TCI plate to try it and after hacking up my stock flexplate to get the splined retainer off, realised that there is no way it would get within light years of bolting up.
Old Aug 14, 2007 | 05:56 PM
Ram Air T/A's Avatar
Ram Air T/A
One good thing is that you took it in now before it was too late. Is there a blanket for those cars or shields ????.
Old Aug 14, 2007 | 06:24 PM
roythomas's Avatar
roythomas
no !!!!! strait threw the floor & your a one legged pirate ...
Old Aug 14, 2007 | 08:25 PM
0EG@EnglandGreen
Supporting Tuner
Yes. Cajundude (Jason) used a kevlar blanket on his 800rwhp MN6 clutch, but it will fit on a A4 bellhousing. Send Jason a PM for details.
Stephen
Old Aug 14, 2007 | 09:42 PM
Cajundude's Avatar
Cajundude
Active Streak: 90 Days
Cruise-In 7-8-9-10 Veteran
St. Jude Donor '06-'07-'08-'09-'10-'11-'12
I think the blanket is more of a PITA than it's worth unless of course it actually works. There is no way you are going to properly install it with the engine in the car. While I'm glad I have it just in case it does actually work, it can be a hindrance at times. If you have long tubes the bottom of the blanket will burn off, burn partially, hang down or do whatever it wants. After several months when the stink finishes burning off of your headers and you are left with just the top half it does give the impression that it might work should your flywheel or clutch explode.
Old Aug 14, 2007 | 11:34 PM
roythomas's Avatar
roythomas
IF YOU GUYS SAW THE SHAPE OF THAT PLATE !!! THE CENTER WAS TORN OUT..AND I NEVER EVEN RACED MY VETTE
To flex plate carnage !!!!
