**Best Head Gasket**
Old Aug 16, 2007 | 03:53 PM
Boosted04Z06's Avatar
Boosted04Z06
Default **Best Head Gasket**
Hey guys, if you have read my other thread, you will know I am rebuilding my ls6 engine now.....what would be the best head gasket for the forced induction application? I am running about 6.5 psi.
Thanks,
Dustin
Old Aug 16, 2007 | 04:09 PM
nmp27's Avatar
nmp27
Stock GM works fine, and easier on the back pocket
Old Aug 16, 2007 | 04:38 PM
Shinobi'sZ's Avatar
Shinobi'sZ
Thanks,
Dustin
You can't beat the GM MLS gaskets for most applications. The only reason I am not running the GM gaskets is because I had a deck height change due to my piston/rod combo and having had milled the block and heads for trueness.
I have been using Cometic MLS gaskets now for sometime because I needed a custom size. I have had 0 issues with them up to 18#s of boost. No leaking or sealing issues either.
Old Aug 17, 2007 | 01:27 AM
jbsblownc5's Avatar
jbsblownc5
2017 C5 of the Year Finalist
St. Jude Donor '08
[QUOTE=Shinobi'sZ;1561528037
I have been using Cometic MLS gaskets now for sometime because I needed a custom size. I have had 0 issues with them up to 18#s of boost. No leaking or sealing issues either.[/QUOTE]
I'm running a custom sized Cometic as well, no issues.
JB
Old Aug 17, 2007 | 01:52 AM
Tony @ MPH's Avatar
Tony @ MPH
Supporting Vendor
GM MLS works great. Using it in my car at 764rwhp and 792ft/lb.
Old Aug 17, 2007 | 02:07 AM
2004SpiralGrey's Avatar
2004SpiralGrey
Cometic MLS - 3.910" bore .065" thick
To **Best Head Gasket**
