hi guys its been a long while since i posted any problems but it seems to have arrived and in Ase's
OK here goes
on idle every thing is fine going up and dawn the RPM on light throttle and all is good
nut once i get on it hard and go above 5000RPM i start to lose pressure
i did some testing to see what is damaged
1-i closed the feed line to the regulator and the fuel pressure went way pass 100PSI , so the fuel pumps are good
2-i burrowed a fuel pressure regulator from a Friend and it showed the exact same symptoms
i guess the only other thing is the fuel filter to change and that is what i will do tomorrow
[I would go ahead and change that, it's the easiest and cheapest thing to do. I always start with the small easy stuff and then go from there. What kind of fuel set up do you have, you did say "pumps"
Dan
Dan
I am running 2 intank at the same time and i am using the stock feed line and a /8 return line
i will be upgrading the feed line today to a /10 and i will see haw it gose
From: Tinker till it blows... then back it off a notch, maybe!!
St. Jude Donor '08
Do you still have the diagram of how things are connected, plumbed?
Sounds like even though you have pressure, you don't have volume under higher load.
What does the pressure drop off to?
Good move changing the feed line anyhow, but just wondering why it was working before and not now? Maybe one of the pumps is going or a something in the tank?
Good luck with it
rjw
the presure drops of to 3BAR
and the car is leaning out
