Sledgehammer!
Old Sep 20, 2007 | 12:33 AM
Shinobi'sZ's Avatar
Shinobi'sZ
Default Sledgehammer!
So why was the Twin Turbo Callaway "Sledgehammer" able to get to a top speed of almost 255mph....and no C5 or C6 Force Inducted vehicles can?
Was/is the C4 more aerodynamic. Something should account for this car being able to get that speed with a SBC and TTs. Just curious if anybody knows.
Old Sep 20, 2007 | 01:04 AM
Red C5's Avatar
Red C5
Late C4:
drag coefficient: 0.330 frontal area: 19.00 sq/ft
C5 is like .29
Maybe no one has really attempted to break it.
Old Sep 20, 2007 | 01:18 AM
eric04's Avatar
eric04
i dont know for sure but maybe the zf 6spd is geared different then our c5z, i think our top speed is in 5th gear and i think its like .7 which is very close to our 4th gear maybe the zf is more like .6 or something i am sure someone will post the exact ratios after i put this up, also i think the sledghammer top speed was at the salt flats and they took as long as they want, maybe nobody has done that with the c5 z i maybe way off here but its a thought,
Old Sep 20, 2007 | 01:25 AM
HRTBRCR's Avatar
HRTBRCR
Default sledgehammer
their record run was at the ohio test facility....the motor was a one off race piece which had 500 large invested in it....with the aerodynamics and the motor...John Lingenfelter I think helped with the build....
Old Sep 20, 2007 | 05:30 AM
SpeedyD's Avatar
SpeedyD
I think the answer can be summed up with two words:
John Lingenfelter
Old Sep 20, 2007 | 07:02 AM
Jerseyboy's Avatar
Jerseyboy
John Lingenfelter built the engine for the Sledghammer and actually drove the car to the 254mph top speed at the Transportation Research and Development Center in Ohio. Rumor is Reeves Callaway was running the car but backed out at around 230mph. John knew the car had more into it so he jumped in and ran it himself. The rest is history.
I don't think anyone has really tried to break the record with a C5 or C6. If LPE's new C6 Z06 can do 226mph in a standing mile, I'm sure it can break 255mph around a test track. Now you just have to convince them to go after the record!
Jersey
Old Sep 20, 2007 | 07:50 AM
vetterlatethannever's Avatar
vetterlatethannever
John Lingenfelter
Old Sep 20, 2007 | 09:06 AM
RED99's Avatar
RED99
Speedweek was last week. All of your answers are there.
Old Sep 20, 2007 | 09:46 AM
SpeedyD's Avatar
SpeedyD
More info please!!
Old Sep 20, 2007 | 09:59 AM
LPDesRoche's Avatar
LPDesRoche
I once read a quote from John Lingenfelter himself that said even though the C5 has less of a coefficient of drag than the C4 the C4 was much more stable above 200 than the C5. He would know more than most of us since I am sure he drove both models in excess of 200mph more than a few times. That may have something to do with it as well..
Old Sep 20, 2007 | 10:55 AM
Shinobi'sZ's Avatar
Shinobi'sZ
Thats what I remembered hearing too. Didn't the Sledgehammer utilize a auto 700R4 tranny? That could have been the other BK2 designations. The BK2 was said to use the Truck Block because it had a 4 bolt main....understandable I have first hand experience breaking (2) 2 bolt main blocks in my old 87 IROC (when I used to frequent the strip).
It was said to have dyno'd at 880hp as well...didn't say whether it was wheels or brake hp. It seems either or hp rating it was fast as hell.
Old Sep 20, 2007 | 11:15 AM
SpeedyD's Avatar
SpeedyD
I've personally had my car up to 190, and even though it got there quick I couldn't imagine piloting it another 65mph!!! I'm sure the first 200 runs off pretty quick, but that next 65 must take a while! A lot of time for things to go hay wire, and if things were to start unraveling, it would happen very quickly!!!
200 will be coming shortly for me, video to follow! Gotta love the G-Force gearing!!
Dan
Old Sep 20, 2007 | 12:15 PM
FreddyG's Avatar
FreddyG
Whether it's RWHP or BHP, 880 is ALOT of power!
Either way, there are cars on this forum that put out that power (you're one of them Kevin), but if you look at the SledgeHammer, it was built for high speed charges like that! Just look at all of the ducts on the car! as the car goes faster, the more that aerodynamics plays a roll. A car can get to 200 mph, pretty painlessly, but every MPH after that comes MUCH harder because the air is pushing back then!
Just check it out and look at all of the ducting:
SledgeHammer pictures........................
Old Sep 20, 2007 | 01:10 PM
LPDesRoche's Avatar
LPDesRoche
Thats what I remembered hearing too. Didn't the Sledgehammer utilize a auto 700R4 tranny? That could have been the other BK2 designations. The BK2 was said to use the Truck Block because it had a 4 bolt main.....
The regular B2K cars with the auto option (very few of them) had a turbo 400 with a gear vendors type of OD unit on them. It was not an actual Gear Vendors unit, but something just like it from another manufacturer.
I am pretty sure the blocks had splayed mains or at least billet caps. Can't remember for sure anymore. They had other improved internals, but heads and intake were stock items (on the regular B2K's)
Old Sep 20, 2007 | 01:20 PM
SurfnSun's Avatar
SurfnSun
St. Jude Donor '10
John Lingenfelter
I assume youre talking about him driving the car.
FWIW...LPE built some R&D motors for the project but a Callaway built motor made the run and resides in the car today.
Its absolutely ridiculous the number of uninformed fans that credit him with the car's performance...yet for some reason its called the CALLAWAY Sledgehammer. This same topic is alive in C4 right now.
Even if it was an LPE short block in the car(which its not) really how much of a difference would that make? The engineering of the project was done by Callaway, the build of the car was done by Callaway...John Lingenfelter drove it to its top speed.
Give credit where its due.
Old Sep 20, 2007 | 01:38 PM
SurfnSun's Avatar
SurfnSun
St. Jude Donor '10
The car used a Doug Nash 5 speed. The B2k w/ autos were 400 turbo's with a Gear Vendors/Laycock OD unit mounted on the back of the tranny.
The first 4 87's came with a truck block but the rest of the cars had a motor built by Callaway with splayed 4bolt mains and forged internals.
Old Sep 20, 2007 | 01:42 PM
SurfnSun's Avatar
SurfnSun
St. Jude Donor '10
Jersey
Just to correct the "rumor".... Reeves flew to England during testing after bad weather forecasts and a couple of problems with the car. He'd caught a nasty cold when he returned and thats when JL picked up the driving chores.
To Sledgehammer!
Old Sep 21, 2007 | 12:27 AM
Shinobi'sZ's Avatar
Shinobi'sZ
Thanks for the extra pics...they don't show many in Vette Magazine of it. It makes me wonder where all of that air is going there is no venting on top of the hood to create down force like you see a lot today...just vents in the front.
Good info
Has to be the most expensive mod I have seen to date...only other Vette that would bring more money is a ZL1 or OG Grand Sport (I think)...Corvette Indy must be in there somewhere as well....but this appears to be the most expensive Forced Inducted Vette that I have seen.....and its only a litte 350cid.
Old Sep 21, 2007 | 08:55 AM
SurfnSun's Avatar
SurfnSun
St. Jude Donor '10
Good info
There are two vent in the hood for the air that had come thru the intercoolers.
There are a bunch of pictures here.....
http://www.callawayownersgroup.com/C...ember/cotm.htm
Lots of under hood and under car shots.
Old Sep 21, 2007 | 11:57 AM
bernrex's Avatar
bernrex
Sadly, a new big dog has recently claimed the record.
Link: www.auto-focus.us/autoblog/?p=122
Stats: 1/4 mile in 9-10 second range, traps 180, 0-60 in 2.7 secs ... all from a 6.3 L / V8 with twins [perhaps the 5 generation vette motor thats going into the Blue Devil car ?? ].
