how 9.sec pass's on auto a4
Old 09-20-2007, 05:50 PM
roythomas
roythomas's Avatar
Default how 9.sec pass's on auto a4
just wondering !!! how many guys have 12 or more mid 9.sec pass'es on there a4 ???? i have about 12...
Old 09-20-2007, 06:48 PM
mitymikec
mitymikec's Avatar
I don't have any...lol
Old 09-20-2007, 11:20 PM
roythomas
roythomas's Avatar
a4 is a rare tranny !!!! or there is some slow vettes out here HELLO !!! can you here a echo !!!!! i guess most break then go turbo 400 or two speed
Old 09-20-2007, 11:44 PM
Andre
Andre's Avatar
Honestly Roy, there are not many people with 1 nine second pass... let alone 12!
Old 09-20-2007, 11:49 PM
fsuforever
fsuforever's Avatar
I know 2 vendors on this forum,that can build u a tranny to go in the 9s with no problem s,Rpm & Flt chuck Johnson , i do have a Flt tranny just havent been in the 9s with it Yet !!
Old 09-21-2007, 12:04 AM
STEALTH 99 C5
STEALTH 99 C5's Avatar
I had over 40 9-second runs and over 5000 hard street miles last year on my RPM ( Rodney ) 4L60E , the trans was shifting like brand new when I took it out to do the RPM 4L80E conversion ! RPM builds the best in the business , my Rossler never made it past 10 runs back in the day before RPM came along
Old 09-21-2007, 08:13 AM
roythomas
roythomas's Avatar
40 !!!! holly !!!! are you sure !!!! post your slips please can you give me some tips
Old 09-21-2007, 08:25 AM
LRD VDR
LRD VDR's Avatar
I had a nine sec pass once at band camp!
Nice run!
Shahram
Old 09-21-2007, 10:28 AM
mitymikec
mitymikec's Avatar
Roy, from what i have been told the hard downshifts are what really kill these trannies..Avoid making it downshift from 3-2 under hard accelaration ..
Old 09-21-2007, 10:29 AM
STEALTH 99 C5
Definitely over 40 , I'll give you a tip , BUY A RPM Trans .
Old 09-21-2007, 10:34 AM
gymtitan
gymtitan's Avatar
Default Trans
Lots of them..... in my dreams.
But do hope to get there.
Old 09-21-2007, 10:54 AM
roythomas
roythomas's Avatar
thats a good tip had a m12 held fine diff broke !!!!
Old 09-21-2007, 11:11 AM
asmokegars
asmokegars's Avatar
St. Jude Donor '03-'06-'07-'08
Just to be clear - Mike are you saying that you got 40 9 second passes on the same 4l60 transmission w/o rebuilding it ??
That would be for me vs the turbo400.
Why would you change it out for the 4l80?
Old 09-21-2007, 11:21 AM
roythomas
roythomas's Avatar
thank you !!
Old 09-21-2007, 11:46 AM
FUSW
FUSW's Avatar
I haven't kept track of how many 9 second passes I have made but likely about 20+. I get Marty to re-fresh my tranny once every season and I am good to go.
Old 09-21-2007, 12:23 PM
eb02z06
eb02z06's Avatar
St. Jude Donor '08
At think at the level you are at Roy it probably wouldn't hurt to have a spare tranny/converter incase of breakage. This would save you alot downtime when and if it fails.
Old 09-21-2007, 12:51 PM
STEALTH 99 C5
Because it was still on the edge at the 9.3-9.5 zone , and I want to put more power to the ground , the opportunity for the 4L80 came up and I took it , at the end of last year I made 10 mid 9-second runs in one day , driving to and from the track , and cruising around all night , sometimes I wish I left the RPM 4L60 in .
To how 9.sec pass's on auto a4
Old 09-21-2007, 12:55 PM
RJW
RJW's Avatar
Location: Tinker till it blows... then back it off a notch, maybe!!
St. Jude Donor '08
I did the quarter once in under 9
This was actually 8:30..... minutes.... on foot...
Old 09-21-2007, 01:06 PM
Chris@East Coast Supercharging
Premium Supporting Vendor
Chris@East Coast Supercharging's Avatar
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In V Veteran
I was getting between 10-15 passes before we started using the RPM trans.
Old 09-21-2007, 01:20 PM
0rodney@rpmtransmissions
Former Vendor
rodney@rpmtransmissions's Avatar
Transmission life expectance is to dependant on other parts. I have guys that have destroyed level V's with around 400RWHP. Here are some things that cause trans failures.
Installation error's such as:
Low fluid level
contaminated coolers
improper tuning
pump breakage (converter no all the way back)
misadjusted shifter linkage
blocked/pinched cooler lines
etc....
Driving errors:
hot lapping
repeated 4-2 downshifts
over temp
neutral drops (Hey I have seen it)
wheel hop
Parts failure:
Converter failure
Converter clutch failure
Forward sprag failure
Output shaft failure
Pump rotor failure
Input drum failure
I could go on and on but the key is how you handle the failure and how fast you can get the car back on the road or track.
Quick Reply: how 9.sec pass's on auto a4
