Cobalt gauges - wire hookup - help
Old Sep 27, 2007 | 09:15 AM
RonnieLS1's Avatar
RonnieLS1
Default Cobalt gauges - wire hookup - help
I am currently installing my fuel pressure and boost gauges. Where to I tie in the positive wires to the ignition. The boost gauge has 1 positive and 1 negative. The fuel presure gauge has 2 positive and 1 negative. Negative is self explanatory. I need to know where to tie the positive wires into. I hope it is right underneath the steering wheel somewhere.
Old Sep 27, 2007 | 06:07 PM
chimazo's Avatar
chimazo
I tapped into the unused accessory harness that is under the passenger side floor panel. I ran the wires behind the console. I believe that the harness is there up to early '03, but you can't miss it - it's 3 wires taped off that are not connected to anything - so just pull off the panel and look.
Old Sep 27, 2007 | 09:09 PM
Vega$Vette's Avatar
Vega$Vette
I used the pink wire off the ignition switch.
To Cobalt gauges - wire hookup - help
