Blower cam?
Old Sep 27, 2007 | 03:27 PM
JJ 86's Avatar
JJ 86
Default Blower cam?
Thinking about upgrading to forced induction this winter. I'm looking at buying a procharger system (P1sc) intercooled and installing a cam while I have the steering rack out to install the crank pin kit. What would be a good blower cam? The car would need to remain daily drivable and will see some occasional trips to the track (dragstrip). Any ideas? I'm wanting a good reliable setup that will take some abuse.
Old Sep 27, 2007 | 03:29 PM
ZBad1ne's Avatar
ZBad1ne
I think that the ECS blower cam would be a great option with your setup.
Old Sep 27, 2007 | 03:30 PM
Chris@East Coast Supercharging's Avatar
Premium Supporting Vendor
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In V Veteran
We feel we have a nice cam for your application. It drives very well and makes great power..
Old Sep 27, 2007 | 05:16 PM
HP_Addict's Avatar
HP_Addict
I would like to see a before and after dyno with the blower cam. It would be nice to have a little more torque on the bottom end.
Old Sep 27, 2007 | 07:30 PM
easyvette's Avatar
easyvette
Questions, Are all ECS blower cams for the 347 equal? Or can it be ordered with just a pinch of lope?
I have heard the rumor they do not run that much lift? So is it possibly to run a lighter spring than the .650 lift springs I run now? I hate the valve chatter I hear with my .58X/.59X
Old Sep 27, 2007 | 08:27 PM
Yellow03Z06's Avatar
Yellow03Z06
ECS Blower cam.
My car is cam only with headers for now and it makes power like it was an NA cam. I sometimes wonder if they sent me the right cam There is a very slight lope at idle so you can tell that something is there, but it drives like stock. I hope to add a blower soon and see what this cam really does. Pick the ECS cam and you won't be disappointed.
Old Sep 27, 2007 | 09:33 PM
FactoryRaceCar's Avatar
FactoryRaceCar
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12
I am running ECS 346 Blower Cam and love it
Couple of videos of ECS 346 Blower Cam in this thread
http://forums.corvetteforum.com/show...ght=ecs+blower
Old Sep 27, 2007 | 09:42 PM
fsuforever's Avatar
fsuforever
Originally Posted by Yellow03Z06
ECS Blower cam.
From What Chris Told me ,they have a na cam & a blower cam , & u just may very well have the na cam , contact him & ask , i also know they run the Ecs Blower cams in 402s cuz i just picked 1 up & chris says its Very Streetable for the 402 ,i wouldnt put it in a 416 or a 427 btw my ecs cam ,when it came to the Front Door it was in a comp cam Box & written on the box In Big Black Letters BLower
Old Sep 27, 2007 | 09:45 PM
peter pan's Avatar
peter pan
Life Time NCM #2196
Another good option is the A&A Blower Cam that I have over 9k on my setup and it works just fine and here is a Vid
Old Sep 27, 2007 | 09:49 PM
FactoryRaceCar
Mine said 346 BLOWER
Old Sep 28, 2007 | 12:39 AM
Carl Spackler's Avatar
Carl Spackler
St. Jude Donor '08
Stephen at England Green is installing his Whiplash cam in my P1SC/LG LT equipped mn6 next month. Car is currently 433 rwhp. Whiplash is a pretty hot cam, but Sephen feels confident that, when correctly tuned, its entirely streetable. "Cajundude" has an excellent Whiplash install pic series and vid. Cam upgrade will include new springs and larger updated intercooler. Will post before and after dyno #'s soon. Good luck w/your new set up.
Old Sep 28, 2007 | 09:22 AM
95BlueBomber's Avatar
95BlueBomber
I have said it before and I will say it again... ECS Blower Cam!!!
I have a friend that was lacking power in his boosted WS6 about this cam and he changed nothing but the cam and gained 70RWHP and 77RWTQ Enough Said
Old Sep 28, 2007 | 09:54 AM
HP_Addict's Avatar
HP_Addict
Where in the curve was that 70/77 gained?
When I asked for dyno curves I should have been more specific. I would like to see a supercharged car with a before and after. I am running the ECS Novi, making 568 rwhp, and would like to pick up a little more torque in the lower mid range. It already pulls like a raped ape in the upper range.
Old Sep 28, 2007 | 09:56 AM
95BlueBomber
I honestly dont know, I havent seen the graph... he is on the forum I will PM him to chime in.
This is my ECS Cam dyno results... these are preliminary still... I have to do some tuning and get that A/F straightened out.
Old Sep 28, 2007 | 10:16 AM
JJ 86's Avatar
JJ 86
What kind of power should I expect from the ecs blower cam with a p1sc, longtubes, and full exhaust w/o cats?
Old Sep 28, 2007 | 11:01 AM
Yellow03Z06
Mine said "346 Blower" on the box too.
Old Sep 28, 2007 | 11:22 AM
stevieturbo's Avatar
stevieturbo
And more importantly, what cam was in it in the first place ?
To Blower cam?
Old Sep 28, 2007 | 11:25 AM
easyvette's Avatar
easyvette
I know squat about cam selection this is why I have many questions. But if I read a thread back a while ago correctly. I think Andy (A&A) swapped out a standard LS1 camshaft with an LS7 cam and gained almost 100rwhp. Obviously I`m probably not telling the hole story and boost levels may vary as I dont know the WS6 boost# or remember the boost in the car Andy did and the mod info off hand. Makes this winter project confusing and I`m keep going back and forth.
I`m down to 3 cams (And I know all will preform great)
LS7
TR Blower cam
ECS
Old Sep 28, 2007 | 11:47 AM
JJ 86's Avatar
JJ 86
I remember reading something similar to this as well.
Old Sep 28, 2007 | 12:59 PM
Cruise-In V Veteran
Sorry guys, just been crazy busy but I will try and answer some questions here. The cam is smaller than most others. Its well under 600 lift and well under 230 duration. It took us about 6-8 different cams before we settled on this one. The cam drives almost like stock but makes very nice power. It will easily make over 800 on a 346 with a decent head and our Paxton kit. Not only does it drive awesome and make hude numbers on the dyno but we have great track results as well. We have our 346 cars running 9.7's with this cam and stock bottom end cars with Stock LS1 heads running mid 10's. Dougs car with Trick Flows is a full weight vert with a 346 Paxton and although we never got a full pass it went 117.5 in the 1/8. To my knowledge its one of the fastest street cars here. We can run this cam with 918 springs under 10 pounds of boost and over that we run 921 springs because of the cylinder pressure. Any questions at all feel free to give us a call..
