Fuel Pump Problem
Old Oct 5, 2007 | 10:36 AM
Watch22's Avatar
Watch22
Default Fuel Pump Problem
In the last week or to I have noticed that I'm losing fuel pressure when cruising around town. The fuel pressure starts out around 59psi cold and drops to about 54-55psi after about a 1/2 hour. This is in 65-75 degree air. If I get into boost it drops to about 50-52psi. It used to be rock solid at 59psi and only drop to 56-57psi under boost.
Is this a sign of a failing fuel pump? I still have the stock 2002 fuel system with a Lingenfelter pump
Old Oct 5, 2007 | 11:08 AM
Warp Factor's Avatar
Warp Factor
Put a known-good mechanical gauge on and see what it's really doing.
A number of people have mentioned in the past that sending units can be affected by heat.
My Autometer is no longer accurate........don't know the reason yet.
Fuel pumps are also affected by heat, and the fuel gets darned hot.
Check out diynoob's temperature measurements in THIS THREAD
Old Oct 5, 2007 | 11:11 AM
HP_Addict's Avatar
HP_Addict
yes, keep an eye on it and don't get into boost until it is fixed. Less fuel = lean up top.
Old Oct 5, 2007 | 11:47 AM
SmoothFRC's Avatar
SmoothFRC
May be worth changing the filter out also (if you havent done this in a while)
Old Oct 5, 2007 | 01:03 PM
Watch22's Avatar
Watch22
I just changed the filter last week.
Old Oct 5, 2007 | 01:48 PM
sultan 2 ZR1 KSA's Avatar
sultan 2 ZR1 KSA
pump passing out sorrry for the bad news
To Fuel Pump Problem
