ground in the engine bay?
Old Oct 16, 2007 | 02:07 PM
Tikiman12's Avatar
Tikiman12
Default ground in the engine bay?
solenoid not opening, i think its bc the noid isnt grounded properly. i have it grounded to the hood latch and the frame. but i dont htink its working. any ideas? i dont wanna run the ground inside the car to the one little grounding screw near the B piller.
Old Oct 16, 2007 | 03:34 PM
M_T_0's Avatar
M_T_0
try the neg battery terminal
More Than Zero
Old Oct 16, 2007 | 04:14 PM
Tikiman12's Avatar
Tikiman12
if i wanted to test my solenoid, could i just touch the wores to a 9volt battery? just to test
Old Oct 16, 2007 | 05:39 PM
Vega$Vette's Avatar
Vega$Vette
There is a good ground lug just under the right front corner of the battery tray.
Old Oct 18, 2007 | 04:23 PM
INTHERED's Avatar
INTHERED
There are a number of good factory grounding points on the frame. Did you tie in to one of these ? Maybe its not a grounding problem ?
Old Oct 18, 2007 | 05:14 PM
M_T_0's Avatar
M_T_0
why not just use the 12volt battery that is sitting right next to the noid?
More Than Zero
Old Oct 18, 2007 | 08:53 PM
gary buchanan's Avatar
gary buchanan
there is a sticky on the C-5 tech about ( important electrical info) it has pic's of all the ground points on a C-5
To ground in the engine bay?
